Drives: FRS hot lava
PLUGS?
any recommendations on plugs when going FI? i have been reading up and haven't seen anyone say they have went to a cooler plug.
Drives: 2013 Asphalt FRS
I run stock plugs, but I also have a excellent tuner.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
not playing cards
What if you have a shitty tuner?
Then you can run stock too....
I guess its going to be like what compression you should run, its mostly preference..
Drives: Toyota 86 Turbo, Lexus NX300H
NGK racing plug for fr-s
you should choose #10 for FI . part number is R2558A-10 http://www.rhdjapan.com/ngk-r2558a-r...park-plug.html
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Has anyone tested different plugs for different uses????
| Are these DRL plugs re-pinnable? | BigFatFlip | Electronics | Audio | NAV | Infotainment | 5 | 04-29-2016 07:56 PM |
| Help! From check engine light to fouled plugs back to check engine + plugs refouling | larchamb | Issues | Warranty | Recalls / TSB | 44 | 04-03-2016 09:39 AM |
| Spark plugs | Triumphrider | Engine, Exhaust, Transmission | 12 | 06-19-2014 10:47 AM |
| Where do these plugs go from? | Z3D | BRZ First-Gen (2012+) — General Topics | 10 | 02-18-2013 10:59 AM |
