Old 09-02-2016, 07:17 PM   #1
Im_SPEED
Drives: FRS hot lava
PLUGS?
any recommendations on plugs when going FI? i have been reading up and haven't seen anyone say they have went to a cooler plug.
Im_SPEED is offline   Reply With Quote
Old 09-02-2016, 11:27 PM   #2
FRS Justin
Drives: 2013 Asphalt FRS
I run stock plugs, but I also have a excellent tuner.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 09-03-2016, 12:10 AM   #3
What if you have a shitty tuner?
Old 09-03-2016, 04:47 AM   #4
FRS Justin
Then you can run stock too....
I guess its going to be like what compression you should run, its mostly preference..
710whp
Old 09-03-2016, 07:42 AM   #5
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
NGK racing plug for fr-s
you should choose #10 for FI .
part number is R2558A-10
http://www.rhdjapan.com/ngk-r2558a-r...park-plug.html
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
Old 09-03-2016, 07:44 PM   #6
FRS Justin
Has anyone tested different plugs for different uses????
710whp
Are these DRL plugs re-pinnable? BigFatFlip Electronics | Audio | NAV | Infotainment 5 04-29-2016 07:56 PM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 10:47 AM
Where do these plugs go from? Z3D BRZ First-Gen (2012+) — General Topics 10 02-18-2013 10:59 AM
