Old 08-31-2016, 05:03 PM   #1
etc
Drives: '13 FRS
3d print sound tube delete plug.
Thought I would share here too, I posted it on thingiverse:
http://www.thingiverse.com/thing:1743273
But if you remove your sound tube and need to plug the hole this will do it. I am currently using this on my car. I recommend printing in ABS. PLA's glass transition is only 140f which could be seen in the engine bay.
etc is offline   Reply With Quote
The Following 5 Users Say Thank You to etc For This Useful Post:
8R6 (09-09-2016), BigHugeFatGuy (11-09-2019), Bramick (08-31-2016), ethan160222 (09-01-2016), Gunman (08-31-2016)
Old 08-31-2016, 09:28 PM   #2
Gunman
Drives: 2019 Mazda Miata RF
I may see about kicking one of these out in ultem.
Gunman is offline   Reply With Quote
Old 09-14-2016, 09:37 PM   #3
Gunman
Printed one out, then made a few design changes, and printed another one.
File: https://drive.google.com/open?id=0B0...XdLNDFBWHllMjA
Old 09-14-2016, 11:18 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
[threadjack]
[/threadjack]
Dadhawk (09-15-2016), FX86 (09-21-2016), soulreapersteve (09-15-2016)
Old 09-15-2016, 09:10 PM   #5
etc
Drives: '13 FRS
[threadjack]
[/threadjack]
Lol I actually considered doing just that at first too, had the hole saw out and everything
But decided to go slightly nicer looking, even though I only needed mine on temporarily since I took off my JRSC to have some work done by the dealer.
Also if you want even more ghetto a oil bottle cap (atleast the cap to the rotrex "traction fluid" bottle) fits in there perfectly. I may have run that way for a day or so before printing this.
The Following User Says Thank You to etc For This Useful Post:
Ultramaroon (09-15-2016)
Old 09-15-2016, 09:14 PM   #6
etc
Drives: '13 FRS
Just curious, what did you end up changing?
Depending on when you downloaded the one I posted on thingiverse I made the barrel .25" shorter to fit more flush. I think I slightly adjusted the little nub to fit in the slot better at one point too.
Old 09-15-2016, 10:03 PM   #7
Ultramaroon
not playing cards
Man, that's great. It was actually a scrap in my hand on the way to the trash when I snapped to the idea. Reduce, reuse, recycle.
Old 09-16-2016, 07:28 AM   #8
Gunman
I downloaded on Aug 31. I did both of those things, and added a bit of recess along the main barrel, to let the hose clamp compress the rubber in a bit, to aid in retention. Added a lead in chamfer to aid in installation a wee bit.
Also the first was made solid, the second is sparse filled, much lighter.
If I did another rev. I'd try to match the shape/curve of the tube, on the inside
Old 09-16-2016, 01:52 PM   #9
Ultramaroon
not playing cards
Bingo. At least on mine it looks like there used to be wall/diaphragm which was manually cut out. Definitely more than flashing. I sanded down my ghetto plug to fit.
Butt dyno says about 2 HP. What software are you guys using to create the geometry?
Old 09-16-2016, 05:51 PM   #10
Gunman
I'm a Siemens NX cad jockey.
Old 09-16-2016, 06:13 PM   #11
Ultramaroon
not playing cards
Wow! Small world. I'm no jockey but I use it.
Old 09-16-2016, 06:30 PM   #12
Gunman
My coworkers say it runs much deeper in me, I've been using it since it was Unigraphics v8. yeah...
The Following User Says Thank You to Gunman For This Useful Post:
Ultramaroon (09-16-2016)
Old 09-16-2016, 10:00 PM   #13
Ultramaroon
not playing cards
Autocad, Pro/E 19-2001, Solidworks, CATIA V5r19, NX 9-10
I never really learned V4 and I don't feel as though I'm missing out on anything. :P
Old 09-20-2016, 07:11 PM   #14
etc
Drives: '13 FRS
I am feeling like a noob over here with my passable onshape.com skills
FS: Sound Delete Plug (NJ) zc06_kisstherain Engine, Exhaust, Bolt-Ons 8 04-04-2016 06:35 PM
FS: Sound Delete Plug (NJ) zc06_kisstherain Engine, Exhaust, Bolt-Ons 14 02-21-2016 12:02 AM
sound tube plug? ft86me Engine, Exhaust, Transmission 23 12-21-2014 10:27 PM
wtb: sound tube delete inlet tube Jimmy817 Engine, Exhaust, Bolt-Ons 1 12-21-2014 10:15 AM
Damn near free sound tube plug Narcoden DIY (Do-It-Yourself) Guides 8 03-30-2013 12:55 AM
