Old 08-30-2016, 06:05 PM   #1
New SPL Front lower control arm (FLCA) discussion
https://www.instagram.com/p/BJv7qkHgTQb/
Rumor has it the official press release will be coming soon... any guesses as to what this is?
Old 08-30-2016, 06:15 PM   #2
byun
byun's Avatar
Drives: 2015 BRZ CWP
Front lower control arms...
byun is offline   Reply With Quote
Old 08-30-2016, 06:24 PM   #3
whataboutbob
AutoX-10/10ths every run
^ This!!!!
Build thread:Here
Old 08-30-2016, 09:09 PM   #4
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
http://www.ft86speedfactory.com/spl-...l#.V8YuRp8fNnE
JDKane527 is offline   Reply With Quote
Old 08-30-2016, 09:45 PM   #5
808_ft86
Drives: 13 frs
I got my set in the mail yesterday. Can't wait to get it on the car.
808_ft86 is offline   Reply With Quote
Old 08-31-2016, 07:43 PM   #6
enivid
enivid's Avatar
Drives: WRB JR BRZED
Why so expensive!
Sent from my Nexus 5X using Tapatalk
enivid is offline   Reply With Quote
Old 08-31-2016, 09:07 PM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by enivid View Post
Why so expensive!
SPL TITANIUM FRONT LOWER CONTROL ARMS
Dat titanium
2013 FRS
Vortech V3 11psi
Old 09-01-2016, 12:16 PM   #8
Jonsey
Jonsey's Avatar
So what are the substantial advantages going to be besides weight reduction and strength? My car is at the shop now and they are going to be installing the Whiteline roll correction kit and a whiteline bushing in the front lower control arms. Wondering if the benefits would justify sending those parts back and ordering these.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
Old 09-01-2016, 01:06 PM   #9
This SPL FLCA basically obsoleted quite a few parts on the market for an "unlimited" application. For example, the CSG BRZ has sphericals pressed into the OEM arm; the SPL FLCA does that, for the same price as the bushings and installation labor alone, and more.
The SPL FLCA also allows for *camber adjustment*, caster adjustment, and eliminates two rubber bushings in the front. Combined with a spherical mount top hat/camber plate, you have a zero compliance bushing front.
While it's not cheap, it's a REALLY good value for what it does.
Old 09-01-2016, 03:03 PM   #10
Icecreamtruk
Drives: Track preped NA FRS
I should totally budget for this when switching out my suspension. SPL FLCA, SPL RLCA and JRZ Coilovers hmm.. oh gawd I can only dream.
Old 09-01-2016, 03:11 PM   #11
Hostile_Kittens
Hostile_Kittens's Avatar
Drives: 2015 Subaru BRZ
New SPL part sneak preview
Is SPL planning on making an aluminum version of these too? I'm interested, but dont want to pay for titanium.
Also, how much camber and caster adjustment do these allow for?
Hostile_Kittens is offline   Reply With Quote
Old 09-01-2016, 03:39 PM   #12
strat61caster
strat61caster's Avatar
From what I've seen of SPL products and what's pictured here, the amount of titanium components is actually pretty small, a couple nuts and washers. The major piece parts, rods/arms, joints, and bolts are usually typical aluminum and steel. I'd be surprised if SPL could discount the parts by more than $20-$50 by swapping out all the Ti hardware.
The money goes into engineering, quality control, marketing, and compensating for relatively small production runs. Like their rear lower control arm, I'm positive the big black arms SPL makes are standard 6061 anodized Aluminum for both their lower control arms on the 86.
ineedyourdiddly
Old 09-01-2016, 03:51 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Another thing to consider is upper mount.
The SPL lower arm can be paired with a solid upper mount like the ones pictured above, so that you can get 1) max camber/caster flexibility in the front, and 2) a suspension setup that won't move around on you.
Or, if you want to go uber stance 9000, this combo setup allows you to go wild in the front.
-alex
Old 09-01-2016, 06:36 PM   #14
@strat61caster is correct; the key points are titanium, and the rest is primarily aluminum.
New Turbo Kit Sneak Peek(Ptuning) kanundrum Forced Induction 1046 10-26-2017 07:02 AM
Part 1 of our FR-S / BRZ Turbo Kit Sneak Peek Rev Works Forced Induction 64 03-12-2014 01:21 PM
A Sneaky Sneak Peak? White64Goat Other Vehicles & General Automotive Discussions 2 02-20-2013 04:03 PM
Sneak peek at new 57Xtreme? vividracing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-07-2013 02:24 PM
Sneak preview at the Motiv Concepts Exhaust MotivConcepts Engine, Exhaust, Transmission 36 11-21-2012 08:17 PM
