Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 08-30-2016, 04:56 PM   #1
Manofsteel
Drives: 2013 frs
Lowering springs install
I'm looking for a reasonable $$$$ shop to install lowering springs in New Jersey. I have been to 2 shops including Krazy House and they cost is crazy over $1,000. Does anyone have a recommendation? I appreciate the help. Thank you.
Manofsteel is offline   Reply With Quote
The Following User Says Thank You to Manofsteel For This Useful Post:
Filipino Royale (08-30-2016)
Old 08-30-2016, 04:59 PM   #2
NA_FRS86
Drives: 2015 Scion FRS
Check out AZPinstalls. I have yet to work with these guys since I am still deployed. but I have heard nothing but amazing reviews from them. I already have plans to have them do my whole suspension upgrade with my FRS and they have been very helpful with what im looking into getting for daily and track set ups.
NA_FRS86 is offline   Reply With Quote
Old 08-30-2016, 04:59 PM   #3
gramicci101
Off Topic
@AZP Installs.
edit - beaten to the punch.
The Following User Says Thank You to gramicci101 For This Useful Post:
NA_FRS86 (08-30-2016)
Old 08-30-2016, 05:01 PM   #4
NA_FRS86
Originally Posted by gramicci101 View Post
@AZP Installs.
hahaha yeah but I like your taste in shops
The Following User Says Thank You to NA_FRS86 For This Useful Post:
gramicci101 (08-30-2016)
Old 08-30-2016, 05:05 PM   #5
Manofsteel
Drives: 2013 frs
Thank you gramicci101 and NA FRS86. I will reach out to them. And thank you NA for your service
Old 08-30-2016, 05:26 PM   #6
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Just to give you a point of reference. Brady @Pure Automotive installed my RCE yellows, SPC lower control arms and crash bolts (I supplied the parts) for about tree fiddy. Actually, it was exactly $350.00.
BirdTRD is offline   Reply With Quote
Old 08-30-2016, 09:01 PM   #7
Filipino Royale
Got Rice?
Filipino Royale's Avatar
Drives: 37J BRZ-L
Check pm
Be a Leader, Be a Friend, Be at Service. -AɸΩ
Filipino Royale is offline   Reply With Quote
Old 08-31-2016, 03:31 PM   #8
bfrank1972
Drives: 2013 FR-S Argento
Christ. I guess they're trying to live up to their name. That is crazy. Please tell me that at least includes camber bolts and a performance alignment.
bfrank1972 is offline   Reply With Quote
Old 08-31-2016, 03:36 PM   #9
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Plus an HJ and a ZJ...
I literally installed those myself in under an hour (albeit on a lift and not Jack stands
Toyarzee is offline   Reply With Quote
The Following User Says Thank You to Toyarzee For This Useful Post:
bfrank1972 (08-31-2016)
Old 08-31-2016, 05:27 PM   #10
Manofsteel
Drives: 2013 frs
It did include the 4 wheel alignment but that wasn't the only shop 3 others quoted the same. They look it up in their pricing computer and it states 8 hr installation. Very disappointed.
Old 08-31-2016, 05:29 PM   #11
gramicci101
Off Topic
By myself, on jack stands, having never done springs before so I was taking my time, it wasn't even two hours.
Old 08-31-2016, 05:39 PM   #12
bfrank1972
Uh wow you guys are fast! Takes me around 3 hours taking my time:
- pull car up on blocks (ok it's already lowered, just swapped coilovers)
- jack car up
- place jack stands, lower car, re-snug jack
- remove front tires
- unhook clips, lines, sway links
- unbolt knuckle, unbolt top, remove struts
- replace, bolt up, clip, attempt very rough ballpark camber
- re-torque everything to spec
- replace wheels & lugs, raise, remove stands, lower for tire contact, torque lugs, lower all the way
- back off boards
- repeat everything for the rear
and that's not actually replacing the springs (though I do spend a little time playing with ride height). No way I could do all that in < 2 hours, what am I doing wrong?
Old 08-31-2016, 06:18 PM   #13
gramicci101
Off Topic
If you're only changing springs, not struts or coilovers, you only need to unbolt the top nut, the brake line clip, and the swaybar nut. The springs are on so little static load that you can unbolt the nut and let the spring decompress as you raise the car. You just need to be careful fishing it out of the fender. The only special tools needed are a pass-through socket set and long allen wrenches.
DIYs:
DarrenDriven's very comprehensive strut remove/replace DIY
http://www.ft86club.com/forums/showthread.php?t=10842
Jeebus' simpler spring remove/replace DIY (builds off of Darren's)
http://www.ft86club.com/forums/showthread.php?t=32414
Read both in their entirety before attempting. There is good info all through both threads.
Example:
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
bfrank1972 (08-31-2016), carsebuco (12-09-2017)
Old 08-31-2016, 06:25 PM   #14
bfrank1972
Wow no spring compressors! Learn something new every day.
Sent from my SM-N920V using Tapatalk
Racecomp Engineering Yellow lowering springs install special! Racecomp Engineering Mid-Atlantic 12 12-17-2015 01:34 PM
San Diego Lowering Springs Install Roneezy Southern California 4 08-26-2015 03:14 PM
which lowering springs should I get? abling2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-22-2013 02:27 PM
Lowering Springs install help HATED1 Northwest 6 03-10-2013 03:47 PM
Looking for a place to install lowering springs in DFW area frs_firestorm Southwest 7 02-16-2013 12:55 AM
