Old 08-29-2016, 01:36 AM   #1
mattaubel
mattaubel's Avatar
Drives: 2015 FRS
Help :( tranny issues
I started noticing a grinding noise between 2500-4000 rpm while decelerating (engine braking) in 5th gear. Push in the clutch it goes away, go below 2500 rpm it goes away. It is also faint when in 4th gear. No grinding when I am shifting, and no other new noises.
It started after I had a kartboy short shifter/rear bushing and a ACT 6 puck (with springs) clutch installed both in the same job.
I don't think it's synchros cause it isn't happening when I shift between the gears.. Flywheel is stock so its not from a lightened flywheel. It's not a normal whur sound or a rattle... Maybe its worn down gears but I mean that doesn't make sense since I only put on 3000 miles on it when I bought it used with 7000 miles on the odometer..
Looking through the forums most people are saying if its grinding its probably the synchros or a throw out bearing or an input shaft bearing.
Anyone have a similar sound from their tranny? Its just confusing to me since I haven't experienced something like this thats RPM specific.
Thanks in advance.
Worst case scenario I go back to stock and see if warranty will replace my tranny.
mattaubel is offline   Reply With Quote
Old 08-29-2016, 02:18 AM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Post a sound clip.
Old 08-29-2016, 02:19 AM   #3
humfrz
I'd start there .........
humfrz
Old 08-29-2016, 02:47 AM   #4
mattaubel
mattaubel's Avatar
Drives: 2015 FRS
Post a sound clip.
Will do tomorrow
Old 08-29-2016, 02:48 AM   #5
mattaubel
mattaubel's Avatar
Drives: 2015 FRS
humfrz
Maybe it's just the sound of my new clutch and something I need to get used to? I'll post sound clips tomorrow though
The Following User Says Thank You to mattaubel For This Useful Post:
humfrz (08-29-2016)
Old 08-29-2016, 06:24 PM   #6
mattaubel
mattaubel's Avatar
Drives: 2015 FRS
Post a sound clip.
[ame="https://www.youtube.com/watch?v=DEgWEItRfdw"]Grind - YouTube[/ame]
Sound clip. This is in 5th gear accelerating to 3000 rpm and then releasing gas, it ends at 2000 rpm.
Old 08-29-2016, 06:25 PM   #7
mattaubel
mattaubel's Avatar
Drives: 2015 FRS
Also, it is not the shift knob rattle.. that's a different sound that I am used to haha
Old 08-29-2016, 06:38 PM   #8
wbradley
Sarcastic SOB
wbradley's Avatar
Tell her...I mean him to lose your phone number
The Following User Says Thank You to wbradley For This Useful Post:
justatroll (08-29-2016)
Old 08-29-2016, 06:38 PM   #9
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
The joys of a puck clutch!
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
mattaubel (08-29-2016)
Old 08-29-2016, 06:46 PM   #10
Ultramaroon
not playing cards
Well here's the thing that is unique about fifth gear. It is the only gear in which the transmission doesn't do anything. The input shaft that sticks into the clutch disc is connected straight to the output shaft which sticks into the drive shaft.
I'll put money on something rattling in the clutch.
That's a really good recording, BTW.
Drakiv (08-29-2016), mattaubel (08-29-2016)
Old 08-29-2016, 06:51 PM   #11
mattaubel
mattaubel's Avatar
Drives: 2015 FRS
Didn't know that thanks so much! Guess it's just a sound I'll have to get used to.
Old 08-29-2016, 07:05 PM   #12
mattaubel
mattaubel's Avatar
Drives: 2015 FRS
Also some extra information, trans fluid was really black when I swapped the clutch.. Only 10,000 miles on it so who knows
Old 08-29-2016, 07:28 PM   #13
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
What fluid are you running? I would swap to Motul, it is seriously amazing. I have now run Amsoil, Motul, and the stuff im on now Neo Synthetic. Neo Synthetic takes the cake, however Motul is above Amsoil in feel. It really makes your transmission a different beast just from the gear oil you pick.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 08-29-2016, 08:23 PM   #14
mattaubel
mattaubel's Avatar
Drives: 2015 FRS
Currently running redline. If anyone is reading this and just got their 86 I highly recommend you change your granny fluid.. I had it for 2 months when the clutch blew out and it's a certified preowned that the dealer claimed had a x whatever point inspection and fluid check... BS. Tranny fluid was black as ever
Drakiv (08-29-2016)
STI JDM tranny mount vs Perrin tranny support NVH khrono Engine, Exhaust, Transmission 2 03-15-2016 08:43 PM
Auto FI Tranny Issues? zkahle Forced Induction 10 12-17-2015 04:33 AM
Is this engine or tranny issues? 86Hiro Engine, Exhaust, Transmission 9 09-23-2015 02:51 PM
Windows, Tranny/clutch, dealer issues. Help! Chalk Issues | Warranty | Recalls / TSB 9 02-15-2015 03:11 PM
MT vs AT tranny... better MPG, 0-60? subatoy BRZ First-Gen (2012+) — General Topics 163 03-26-2012 06:08 PM
