Old 08-28-2016, 10:26 PM   #1
junkyard
Drives: 2014 BRZ
Can you identify this bolt?
Hey all. Just bought a used 2014 BRZ and found this bolt in the glove box. Anyone know what its purpose is/was?
Thanks!
junkyard is offline   Reply With Quote
Old 08-28-2016, 10:42 PM   #2
gramicci101
Off Topic
That's an oil pan drain plug. Kind of necessary, so I'd check the oil pan super freaking ASAP. That said, if they switched to a fumoto valve, then the drain plug is no longer necessary.
Old 08-28-2016, 10:45 PM   #3
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Weird it would be in the glove box. I know some people have had trouble with the thread on these bolt stripping especially the first oil change done. Check thread on that bolt see if they're still good.
tofurun is offline   Reply With Quote
Old 08-28-2016, 11:48 PM   #4
ryoma
ryoma's Avatar
lol it's never a good thing to find the oil plug in your glove box...
Old 08-29-2016, 12:05 AM   #5
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Frankenstein's Monster's neck bolt.
Old 08-29-2016, 12:18 AM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
spark plug delete kit
Old 08-29-2016, 12:29 AM   #7
e1_griego
e1_griego's Avatar
Drives: Many
rod bearing delete kit
fixed*
e1_griego is online now   Reply With Quote
Old 08-29-2016, 12:46 AM   #8
humfrz
Thanks!
Yep, it's an oil pan drain plug for sure.
Looks like the threads are full of metal from the oil pan.
Most likely they stripped the threads out and just super glued some bolt in the drain plug hole.
Not to worry ........ until you change the oil ........
humfrz - jest ah messen wich ya..........
Old 08-29-2016, 01:10 AM   #9
Ultramaroon
not playing cards
Originally Posted by e1_griego View Post
fixed*
Agreed. Much better.
Old 08-29-2016, 06:36 AM   #10
junkyard
Drives: 2014 BRZ
Ha. Thanks for the entertaining responses. I better get my head under there to see what's in its place.
Old 08-29-2016, 06:48 AM   #11
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Err oem oil pan bolt, the previous owner probably has one of those magnetic bolts in place of the oem one.
But you had me worry there when you need to ask what bolt that is.. 😂
Old 08-29-2016, 07:57 AM   #12
wbradley
Sarcastic SOB
wbradley's Avatar
Check if there's oil in the trunk!
Old 08-29-2016, 09:22 AM   #13
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
So seeing as how the threads look super buggered up, I'd bring that to the dealers attention and ask them to confirm the drain plug in the car is fine. (Have them remove it to verify, and reinstall.) If it's threaded, have them do a new pan. Don't bother with chasing the threads imo.
If it's a magnetic plug or fumoto valve or something, I'd be slightly less concerned, but it could be just your potato pic that makes the threads look so bad.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 08-29-2016, 09:30 AM   #14
Wow loads of paranoia for a bolt in a glove box.
Look at dipstick. Is there enough oil?
Look under car. Is there any oil on the ground?
If yes and then no don't sweat things until your next oil change.
If no and then yes you have a problem and the paranoid guys were right.
Camber bolt + suspension bolt torque settings LostSalad DIY (Do-It-Yourself) Guides 3 05-09-2016 09:29 AM
Can anyone identify this front lip? t00n3wb Cosmetic Modification (Interior/Exterior/Lighting) 4 02-09-2016 01:11 PM
Can't identify this car Bg8780 Other Vehicles & General Automotive Discussions 23 11-19-2013 04:31 PM
Help me identify this car jimmillion Other Vehicles & General Automotive Discussions 14 09-13-2012 10:09 AM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
