Old 08-27-2016, 10:22 AM   #1
radroach
Drives: car
Balancing rear weight
From the OEM Audio+ threads about the subwoofer, somebody reported that the stock setup on these cars is 30lbs underweight in the right rear and that adding a subwoofer fixes the weight distribution in the car. Can anybody confirm? And if so, will it provide better stability?
Old 08-27-2016, 10:26 AM   #2
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I don't think so. The car is very good balanced with an average driver weight. Together with the driver, you have almost same weight in both diagonals.
weight(LF) + weight(RR) ~ weight(RF) +weigh(LR)
LF: Left Front
RR: Right Rear
RF: Right Front
LR: Left Rear
EDIT:
Check the weight of a stock car with a 175lbs driver here: http://www.ft86club.com/forums/showp...89&postcount=1
Old 08-28-2016, 02:43 PM   #3
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
If you're 230lbs like me, go ahead and put that subwoofer in is my take. Good data from nikitopo, thanks.
jeepmor is offline   Reply With Quote
The Following User Says Thank You to jeepmor For This Useful Post:
radroach (08-29-2016)
Old 08-28-2016, 03:17 PM   #4
ryoma
ryoma's Avatar
if you already have adjustable suspension like coilovers, then get a corner balance. you can solve your problem without spending $1500+ for the OEM audio+ setup.
Old 08-28-2016, 04:40 PM   #5
redlined600
redlined600's Avatar
Drives: Fr-s
I'll take less weight over an ideal weight distribution every time.
The Following 5 Users Say Thank You to redlined600 For This Useful Post:
Captain Snooze (08-31-2016), finch1750 (08-29-2016), strat61caster (09-06-2016), wparsons (08-28-2016), ZionsWrath (08-28-2016)
Old 08-31-2016, 03:18 AM   #6
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
This.
Old 08-31-2016, 07:28 AM   #7
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
That was me. Before:
After:
The car has TRD springs and I am 170 lbs.
I didn't do the sound system to improve performance. I simply could not stand the stock system and was pleasantly surprised to learn that it doesn't hurt the corner balance of the car.. (it actually helps)
More to the OP's question, I wouldn't expect a noticable difference in performance (good or bad) from such a small amount of weight.
Twinz is offline   Reply With Quote
Old 09-05-2016, 06:36 PM   #8
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
You'd get better value from refueling more often.
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
Corner balancing phongtphan21 Northern California 15 04-07-2016 02:53 AM
Tell me about corner balancing.... wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 01-14-2015 10:39 PM
Corner Balancing ExxelDistributions Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 08-30-2014 12:43 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 11:38 AM
Where does all the rear weight come from? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 50 09-23-2012 03:08 PM
