Old 08-24-2016, 07:33 PM   #1
DemonRawr
Drives: 2014 BRZ Limited 6M
Need Help on 4th Brake Light Wiring
Solved!
DemonRawr is offline   Reply With Quote
Old 08-24-2016, 10:37 PM   #2
HachiRo
Drives: 2013 White-Out FRS
Which one do you have? The valenti/valenti style or just the bulb?
I wired directly into my light no problem. Black ground wire spliced to black ground wire, and the other two are different for all lights as the color is usually off. Used only the red splice clips also. Re-used them for my RB diffuser and they work fine too lol.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 08-25-2016, 10:40 AM   #3
arkanist
Drives: 2016 BRZ Limited, Stock
Originally Posted by DemonRawr View Post
Solved!
Editing out your question and not giving a response on how you solved it is bad form. If you leave the question and update it with HOW it was solved you help improve the knowledge base this site provides.
arkanist is offline   Reply With Quote
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
4th Brake Light/Rear Fog Wiring issues NickDC88 Cosmetic Modification (Interior/Exterior/Lighting) 18 03-24-2016 10:18 AM
Valenti 3rd brake light wiring SPCorBUST Southern California 4 09-24-2013 11:57 AM
