Old 08-18-2016, 05:35 PM   #1
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Question Is tire pressure different for USA TRD 18" wheels?
I was able to pick up a set of used USA TRD 18 inch staggered wheels and Michelin PSS tires for a good price last week...
I seem to recall that there is a different recommended tire pressure for this setup, and that TRD equipped cars came with a sticker applied over the stock factory recommended pressures.
Can someone supply a picture of the TRD sticker for tire inflation pressure?
Thanks!
nextcar is offline   Reply With Quote
Old 08-24-2016, 01:56 PM   #2
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
Sorry I didn't see your question sooner. Answered your PM.
Will leave this here for those who need the info.
This is a TRD sticker that's supposed to cover the original one on the door pillar when the 18's are installed.
Part number MDC P/N 00602-18130
Shinigami301 is offline   Reply With Quote
Old 08-24-2016, 02:29 PM   #3
nextcar
Thank you so much!!!
Armed with this information, I attempted to buy this sticker. The Toyota dealerships I called (3!) claim it is not a part they can order. I called the Toyota Material Distribution center - they verify that the part number is correct and that it is in stock, but they cannot sell to end customers, only dealerships. Oh well, at least now the information is available!!!
Old 08-24-2016, 02:40 PM   #4
FX86
Nah man just DIY
all you need is mspaint, a printer and some elmer's glue
Old 08-24-2016, 03:06 PM   #5
ryoma
ryoma's Avatar
is it just me or does 38PSI cold seem pretty high?
Old 08-24-2016, 03:09 PM   #6
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Maybe just sidewall to wheel ratio is smaller... Hence more air. Wide guesses. 🌭
+ the fact that setup is slightly staggered so front is gonna have more weight on it under breaking.
Old 08-24-2016, 03:28 PM   #7
nextcar
Originally Posted by FX86 View Post
Nah man just DIY
DYMO label maker FTW!
Really the only reason to have the label is so that whenever the car is serviced they do not do me any "favors".
Old 08-24-2016, 03:31 PM   #8
FX86
that label maker never wants to work..always says usb device not recognized
Old 08-24-2016, 03:39 PM   #9
nextcar
My guess is to offset the extra grip of the tires and retain more of the native handling...
For that matter, the 35 PSI for the rears on a wider tire is effectively a higher pressure! (e.g same pressure over a larger area...)
That's my armchair physicist analysis, and I'm sticking to it.
Old 08-24-2016, 03:49 PM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Staggered tires, WTF?
Old 08-24-2016, 03:50 PM   #11
Shinigami301
It definitely makes a difference, at least with the Continental DW's- if you run equal pressure, the setup tramlines like a bastard on grooved pavement.
Two pounds difference is enough to completely change the tracking. That three pound difference between front and rear keeps the steering much more sharp than equal pressure front to rear, too.
Old 08-24-2016, 03:54 PM   #12
nextcar
Even worse: staggered rims! The horror!
Old 08-24-2016, 03:58 PM   #13
Shinigami301
Well, this is the "official" TRD configuration. Nobody says you have to go this way, but this is how it comes if you purchase it when you buy the car.
Old 08-24-2016, 04:10 PM   #14
nextcar
They are typical USA TRD parts - a bit more show than go. For me they are a vast improvement from the stock tire and wheel setup... granted that is a pretty easy goal to meet!
tire pressure sensors needed on track only wheels? snuff58 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 11-02-2015 01:48 PM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
Tire Pressure with 16" wheels? fueledbymetal Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-16-2013 09:27 AM
Question: TPMS Tire-pressure monitoring system installed on aftermarket wheels Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-05-2013 12:54 PM
Recommended Tire Pressure for Aftermarket Wheels and Tires Chri5 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-15-2013 01:28 PM
