Drives: 2013 WRB Subaru BRZ
Aftermarket shift knob installation
Hello, so I got a new shift knob and I'm having issues with the installation. When I finish threading it in, the shift pattern is upside down and it always finishes upside down no matter which way I start to thread it in. Does this mean the engraving was down on the wrong side of the knob? Is there any tips you guys can give for me? I'm thinking using loctite, but I just want to see what you guys think first. Thanks
Try some small washers inside the shift knob to change how far it screws on.
Last Starfighter
Drives: 2016 FR-S Series 2.0
definitely don't use loctite, I'd go with the washer method. What brand is it? usually they have a set screw or a counter bolt in the hole to adjust where it stops.
Last Starfighter
#6 | |
That makes sense, thank you! I checked the box thoroughly and sure enough, no nut inside ![]() Emailed them Also saw on their site they posted possible jam possible fitment issues, from switching companies. I didn't even receive one though |
#7 | |
Not sure if this is okay or not..ha |
Drives: Whiteout 6Sp FR-S
Id put a small washer in the hole before using loctight. Just go to Home depot and get some small ones that will fit inside the hole put as many as you need to get it to line up. Trial and error but at least you can then tighten it down.
| Stock shift knob | Jakecrow | Interior Parts (Incl. Lighting) | 14 | 09-01-2016 09:58 AM |
| SOLD: carbing shift knob infocus shift boot digital camo | toby714 | Interior Parts (Incl. Lighting) | 6 | 07-02-2015 09:33 PM |
| FS Raceseng 86 AT Shift Knob and Cusco Red SPin Turn Knob | Unidentified | Interior Parts (Incl. Lighting) | 2 | 01-06-2014 09:55 PM |
| Wtb aftermarket 6at shift knob | BlackyRose | Interior Parts (Incl. Lighting) | 2 | 07-19-2013 09:08 PM |
