Old 08-17-2016, 09:38 PM   #1
kev60625
Drives: 2013 WRB Subaru BRZ
Aftermarket shift knob installation
Hello, so I got a new shift knob and I'm having issues with the installation. When I finish threading it in, the shift pattern is upside down and it always finishes upside down no matter which way I start to thread it in. Does this mean the engraving was down on the wrong side of the knob? Is there any tips you guys can give for me? I'm thinking using loctite, but I just want to see what you guys think first. Thanks
kev60625 is offline   Reply With Quote
Old 08-17-2016, 09:49 PM   #2
White64Goat
Try some small washers inside the shift knob to change how far it screws on.
Old 08-17-2016, 09:56 PM   #3
djwishbone
Last Starfighter
Drives: 2016 FR-S Series 2.0
definitely don't use loctite, I'd go with the washer method. What brand is it? usually they have a set screw or a counter bolt in the hole to adjust where it stops.
djwishbone is offline   Reply With Quote
Old 08-17-2016, 10:10 PM   #4
kev60625
Anarchy motive.
What size washer should I get? Thank you
Old 08-17-2016, 10:21 PM   #5
djwishbone
Last Starfighter
Originally Posted by kev60625 View Post
Anarchy motive.
It should have come with a jam nut. Contact them and they should be able to get you what you need.
Old 08-17-2016, 10:54 PM   #6
kev60625
That makes sense, thank you! I checked the box thoroughly and sure enough, no nut inside
Emailed them
Also saw on their site they posted possible jam possible fitment issues, from switching companies. I didn't even receive one though
Old 08-18-2016, 06:42 PM   #7
kev60625
Emailed them and was told to use loctite...No mention of a jam nut whatsoever. I emailed asking about the nut, but no response..
Not sure if this is okay or not..ha
Old 08-18-2016, 06:54 PM   #8
C130NAV
C130NAV's Avatar
Drives: Whiteout 6Sp FR-S
Id put a small washer in the hole before using loctight. Just go to Home depot and get some small ones that will fit inside the hole put as many as you need to get it to line up. Trial and error but at least you can then tighten it down.
C130NAV is offline   Reply With Quote
Stock shift knob Jakecrow Interior Parts (Incl. Lighting) 14 09-01-2016 09:58 AM
SOLD: carbing shift knob infocus shift boot digital camo toby714 Interior Parts (Incl. Lighting) 6 07-02-2015 09:33 PM
FS Raceseng 86 AT Shift Knob and Cusco Red SPin Turn Knob Unidentified Interior Parts (Incl. Lighting) 2 01-06-2014 09:55 PM
Wtb aftermarket 6at shift knob BlackyRose Interior Parts (Incl. Lighting) 2 07-19-2013 09:08 PM
