Old 08-28-2015, 01:01 PM   #1
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Wideband O2 Sensor questions.
I just picked up an EcuTek ProECU w/ RaceROM as well as an Innovate Motorsports MTX-L Wideband O2 sensor and gauge. I'm curious what folks experiences have been installing the AFR system and getting that information to the EcuTek for datalogging. I'm prepping myself for a Kraftwerks SC install that I'll do this winter when I store the car in the garage.
My main question is, is there any way to replace the rear O2 sensor with the wideband afr. I know with my Corolla the rear O2 sensor was only used for cat efficiency readings and wasn't really needed for the performance of the car. I'll soon be completely catless as my county in PA does not require emissions testing whatsoever.
Thanks in advance for all the help and input!
Frishkorn is offline   Reply With Quote
Old 08-28-2015, 03:35 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
The rear O2 sensor input is the usual way to do it, if you look in the ECUtek help pdf files it will tell you what is needed. Its in the RaceROM help file which has lots of info on the GTR and BRZ setups.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Frishkorn (08-31-2015)
Old 08-29-2015, 05:27 PM   #3
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Yep that's how most tuners do it if I'm not mistaken. You just make a custom map to convert voltage to an AFR reading and you can log that custom map output when datalogging.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
The Following User Says Thank You to zkv476 For This Useful Post:
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
FS: AEM wideband O2 gauge/sensor with failsafe Turbowned Audio/Visual, Electronics, Infotainment, NAV 3 02-23-2015 11:34 PM
WTB: wideband sensor/gauge SterlingBrz Want-To-Buy Requests 0 09-13-2014 11:54 AM
Where does wideband O2 sensor go? Turbowned Forced Induction 8 08-29-2014 02:16 PM
LC-1 wideband 02 sensor MattF Engine, Exhaust, Bolt-Ons 4 11-05-2013 09:52 PM
