Old 08-10-2016, 02:22 PM   #1
Norinradd
Drives: 2013 frs
Such bad mileage!!
Im reading 24 mpg average. I drive 80% of the time casually. Header exhaust tune. Yet i still only get about 240 miles per full tank. Wtf? I bought this car when j sold my jeep as i thought it would get way better mileage. These cars guzzle gas like a hummer
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 08-10-2016, 02:26 PM   #2
wbradley
Sarcastic SOB
wbradley's Avatar
Flash back to stock
Old 08-10-2016, 02:33 PM   #3
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
So it seems that you have a header-back exhaust along with a tune... well yes, you're going to get worse mileage. Better flow means your engine can breathe better... however breathing better also means breathing more. This means your engine will be using a bit more fuel, just the nature of the beast.
Add to that, your tune may eliminate the torque dip, but it serves a purpose and isn't just a random quirk with the car. The range where the torque dip is most commonly found is between 3k to 4.5k, highway cruising RPMs. Essentially, the torque dip helps with the car's MPG while cruising which ultimately helps with emissions. By flattening out the torque curve, you're sacrificing your MPG.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
Old 08-10-2016, 02:39 PM   #4
FX86
why complain about gas mileage when you bought a sports car that requires premium and you put on performance mods that will use more gas? you should have expected the mpg wouldn't be ideal or to your liking
if you can afford the car and the mods you shouldn't have to worry about gas i say
when I had my 370Z i was getting maybe 22mpg...i knew it came with the territory so i just ended up dealing with it
Old 08-10-2016, 02:40 PM   #5
jasonojordan
Drives: 2013 satin white brz limited
Idk what you have going on OP but I get 26mpg highway driving on e85. Over 30 on 93. I have stock headers but rest of the exhaust is catless and also have a tune.
jasonojordan is offline   Reply With Quote
Old 08-10-2016, 02:49 PM   #6
strat61caster
strat61caster's Avatar
How you drive is more important than what you drive. And I don't mean how you keep it <4k rpm or whatever.
Put an 86 on a flat windless highway at 55mph for a day and it will get >35 mpg.
Downhill you might hit 40 mpg.
Put an 86 in stop and go traffic for a day and it will get 19 mpg.
Flog an 86 on the track and it will get 10 mpg.
Put a Prius on a highway at 75mph for a day and it will get <40 mpg and not the 50+ plastered all over the advertising.
Here's my fill up log, averaging ~24-25 mpg with a city driving bias. Highs of ~35, lows of ~10.
http://www.fuelly.com/car/scion/fr-s...7974/fuelchart
Here's EPA ratings for the car, you have reported absolutely nothing abnormal.
https://www.fueleconomy.gov/feg/bymo...ion_FR-S.shtml
ineedyourdiddly
Old 08-10-2016, 02:50 PM   #7
AdrianSaldana
That Guy
AdrianSaldana's Avatar
Drives: Fast and Hard
i have been shifting under 3k to save gas
"Knowledge will give you power, but character respect.."
DD: 2007 Suzuki Sv650
Weekend Car: 1969 Chevelle
Summer/Weekend Car: 2014 BRZ
AdrianSaldana is offline   Reply With Quote
Old 08-10-2016, 02:50 PM   #8
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Manual BRZ is rated at 22mpg city/30mpg highway/25mpg combined by the EPA, so 24mpg is right about where it's supposed to be.
jawn is offline   Reply With Quote
Old 08-10-2016, 02:58 PM   #9
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I get 31mpg on my way to work trying to get good mileage, I get 25mpg on the way back enjoying myself on back roads. Just a catback...
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 08-10-2016, 03:29 PM   #10
Manic
Is not fast.
Manic's Avatar
Can't agree with this more. For my regular commute, give or take 80 miles depending on route, it's 90% freeway with about half an hour's worth of stop and go traffic. However, I love hyper-miling and can usually average between 34-38mpg. My car is mostly stock except for slightly taller tires (225/45 R17) which while being substantially grippier than the stock primacy's, also give it a little bit taller gearing.
By doing things like staying in gear instead of coasting, not trying to close every gap you see, and maintaining speeds when you can, you can drastically improve your gas mileage. But as other's have said, this wasn't a car designed for great mpgs... though it can definitely pull them off.
Granted, when the situation is appropriate, I'll flog this car like the rest. For normal driving though? What's the rush.
If you really want to improve your gas mileage, go back to a stock tune, but I think the extra 5 or 10 dollars at the pump is worth the smile factor (provided you're not driving like a wad).
Old 08-10-2016, 03:32 PM   #11
humfrz
Welp, @Norinradd ........ like said ...... you messed with the engine, now it's messing with your gas mileage.
For your reference, I get about 34 mpg highway, driving at or a bit above the speed limit, with the A/C on.
humfrz
Old 08-10-2016, 03:53 PM   #12
Oh god. For some reason this thread comes as no surprise to me at all.
"like a Hummer" eh??
H1 Hummer
MPG: 9 city/12 highway
As per usual a bit of research could have went a long way before making asinine comments.
Out.
Old 08-10-2016, 03:59 PM   #13
Venom1506
Drives: 16 Ultramarine FRS
Just a catback here. Granted 80% of my M-F driving is just sitting in traffic, but every chance i get im usually romping through the gears and i rarley cruise under 4k. That plus about half a tank worth of hard canyon driving every weekend and i get anywhere between 23-25 mpg (per the read out).
I think thats pretty amazing tbh
Venom1506 is offline   Reply With Quote
Old 08-10-2016, 04:13 PM   #14
JazzleSAURUS
Agree. When I'm having fun in my built motor, VF 6mt Forester, I get like 14mpg. On autocross days I usually get around 10mpg.
I love that the worst I've gotten, (being a fool on most of a tank, doing dyno pulls,) is 22mpg.
What's your mileage!? p1l0t Other Vehicles & General Automotive Discussions 74 04-17-2019 12:11 AM
Gas mileage??? thecarfilmer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 10-22-2015 08:13 AM
OFT 2.063 mileage..... Tromatic Software Tuning 10 03-10-2015 05:47 PM
How much mileage on your FRS/BRZ? AceNiNe Scion FR-S / Toyota 86 GT86 General Forum 5 05-19-2013 07:06 PM
How much mileage do you have on your car now? iff2mastamatt Other Vehicles & General Automotive Discussions 82 01-11-2012 01:48 AM
