Old 03-08-2015, 06:14 PM   #1
Tromatic
OFT 2.063 mileage.....
Jeebus, 27 MPG which is the highest I've ever gotten, and that included a lot of uphill passing lanes and hooliganism.
Tromatic is offline   Reply With Quote
Old 03-08-2015, 07:38 PM   #2
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
My car runs lean on that tune for some reason. I've been working on writing my own which is stable for a 90% stock car (I have just an AEM intake and cut snorkle) and using the 1.5x version tune.
Issue I see, Shifting after a 2nd gear pull creates knock as I enter 3rd. IAM drops to .88 in the 2.063 and .98 in the V 1.5x
Under "standard driving conditions" no knock is present in either tunes, so I am not certain of the issue shy of the snorkle causing HIGHLY turbulent air which makes any reliable tuning hard to do.
Old 03-08-2015, 08:18 PM   #3
steve99
It will most likely be that the maf scaling is way off due to the AEM intake causing high fuel trims during cruise and light throttle and lean/rich conditions during WOT.
you will need to do Closed loop and open loop maf scaling.
If your on a stage 2 tune you may also have to richen up the OL fuel table over 5000 once maf scaling done and or pull some timing.
Old 03-08-2015, 08:23 PM   #4
Tromatic
You're far more in to it than I am. Flash, go, eyeball the OFT for obvious distress, go some more. Butt dyno says that the latest tunes are not quite as stout as the early versions, but they are much more refined. I'm one of those idiots who thinks a stock FR-S is more than entertaining and learning to drive it well is more than part of the attraction, but I'm coming to the conclusion that I want is more torque. You can have your HP, torque is where the fun is. OFT header and some sort of super are in my future.
ETA: Props and kudos to Shiv and crew. It's rare to find a software shop that improves with every release.
Old 03-08-2015, 09:18 PM   #5
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
reason: your AEM intake
As mentioned above, you'll need to modify your MAF scaling values at the very least to get the desired results.
Old 03-08-2015, 10:21 PM   #6
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Slightly off topic... Have you dyno'ed any twins with the TRD intake?
Kostamojen is offline   Reply With Quote
Old 03-08-2015, 10:39 PM   #7
Shiv@Openflash
Drives: 2013 FRS
Yes I've dyno tuned a couple cars with the TRD intake. Works well and doesn't seem to have an effect on MAF calibration.
Old 03-08-2015, 11:34 PM   #8
Kostamojen
Awesome, thats all I wanted to hear
Old 03-10-2015, 03:58 PM   #9
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Is it safe to say that if you're LTFT are off, your MPG will suffer? My LTFTs have been off recently due to exhaust leaks but I've also noticed my MPG suffering. It takes a lot to make it to 27mpg whereas before it would do 33-34 easily.
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 03-10-2015, 05:01 PM   #10
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
You're o2 sensor isn't seeing the correct a/f of the engine, which it is likely injecting more fuel and running much richer then the o2 sensor sees. That's the reason you aren't getting good gas mileage, not because of your LTFTs. However, that does point out the exhaust leak is causing the ECU to react to that situation.
In a properly running car (without an exhaust leak), the LTFT could be off 20% and you can still get 30 mpg. It just means the ECU is doing what it's suppose to, which is compensating for something that is out of wack (typically maf scaling).
eric6 is offline   Reply With Quote
Old 03-10-2015, 05:47 PM   #11
Tromatic
I'm just happy with the mileage. The highest I've ever gotten was 25 on the first full tank. It's usually no better than 22-ish, and 17 with E85. This tank included 100 miles of hiway with long uphill passing lanes and idiots to pass at every one. I'll be very interested to see what the result of this tank will be.
What's your mileage? Aussie Jase Scion FR-S / Toyota 86 GT86 General Forum 54 08-16-2020 08:10 PM
How much mileage on your FRS/BRZ? AceNiNe Scion FR-S / Toyota 86 GT86 General Forum 5 05-19-2013 07:06 PM
Gas Mileage frosty86 Hawaii 12 10-09-2012 04:56 AM
how do you get the gas mileage in you sig? EvoXDD Scion FR-S / Toyota 86 GT86 General Forum 6 07-15-2012 02:22 PM
How much mileage do you have on your car now? iff2mastamatt Other Vehicles & General Automotive Discussions 82 01-11-2012 01:48 AM
