Old 08-08-2016, 09:41 PM   #1
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
SPC Front Camber Bolts (Top or Bottom Hole)
Hi All,
I've read some conflicting information on the boards about the SPC camber bolts for the front of the car about whether they go in the top or bottom slot of the strut. Some people are doing top, others bottom. The instructions said to put them in the bottom hole but my technician installed them in the top hole.
In contrast, I've seen some Whiteline instructions say the top hole is better than the bottom.
Right now, I'm sitting at the following.
Front:
-1.1, -1.2 camber
0.03, 0.04 toe
Rear:
-0.9, -1.5 camber
0.03, 0.01 toe
Any help would be greatly appreciated. Just looking for a mild alignment for 10% autox / track days, 90% daily driving.
Thanks,
n8dog11914 is offline   Reply With Quote
Old 08-08-2016, 09:49 PM   #2
icybrzzz
Drives: 2015 Scion frz
The instructions for my whiteline camber bolts suggested the top holes for the install. They also stated if you wanted a more aggressive setup to use the bottom holes. I personally went for the top hole and got -1.3/-1.3
icybrzzz is offline   Reply With Quote
Old 08-08-2016, 10:07 PM   #3
n8dog11914
n8dog11914's Avatar
Are the Whiteline bolts the same diameter as the SPC bolts though? I've seen several different part numbers. In the end, I'd rather be safe than pushing the envelope with a more aggressive alignment.
Old 08-08-2016, 10:14 PM   #4
icybrzzz
I don't think so, I remember reading something about the whitlines being 16mm and the SPC 14mm. Someone correct me if I'm wrong...
EDIT*
Whiteline makes both a 14mm and 16mm bolt. 14mm installs on the bottom hole and the 16mm in the top. SPC one is supposed to be used in the bottom hole from the quick search I just did as its a 14mm.
Old 08-08-2016, 10:39 PM   #5
Vampyre
Vampyre's Avatar
Drives: 2014 FR-S Asphalt
They are all SPC, whiteline is just rebranded, and it is the size that matters. 14mm bottom 16mm top. I used 14mm camber bolts in the bottom and moved the stock bottom bolts to the top, no aligment at all yet. I am trying to kill my stock tires so I don't feel bad replacing them when I get new wheels..lol
Vampyre is offline   Reply With Quote
OEM front camber bolts B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-30-2014 08:05 PM
WTB Front Camber bolts manualmotive Want-To-Buy Requests 2 04-17-2014 02:45 AM
F/S(NC) New Whiteline Front Camber Bolts - $25 THEWAKLER Brakes, Suspension, Chassis 8 04-07-2014 02:23 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
