Drives: 2013 Silver BRZ
OFT and Auto Transmission
This might be a stupid question but is the OFT compatible with a AT?
Will the OFT lean out a car that might be running rich? Thanks |
It's compatible with AT, though it does not tune your TCU.
If by "rich" you just mean LTFT, you can set your AFR just about however you want, and correct your sensor calibrations. Depends on what is causing your car to run rich.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
Thank you for the reply. Basically I am running the 2.5 inch perrin cold air and I have a 2.5 perrin catback. A buddy at work who heard it says he thinks it sounds rich. He stated that most cars run rich to break in the engine from the factory, but they should be leaned out to get the most power. I noticed a slight bog after I put on the exhaust. I was hoping a OFT tune would possibly fix this. I don't live near a dyno tuner. And obviously I am new to all of this car stuff. Any suggestions?
#4 | |
Drives: 2017 CWP STi
Also, turn on sports mode when you drive, it makes the car way more fun to drive. Instead of 2.5k rpm gear shifts, its now like 3-3.5k shifts |
#5 | |
The only problem is that I live in CA, there are no CARB approved headers that I know of. And I drive the car 95% of the time in "manual" mode, using the shifter to shift up and down. I see you have a AT as well. It is nice to have the ability to auto when you want higher gas mileage. |
#6 | |
If I say yes, will that make you think I understand?
#7 | |
I do not have one yet. I am trying to research my options before I buy. However this looks like the route I will be going. Do you have an AT? What sort of other mods do you have on your car? Is this something that you calibrated yourself? Thanks for the offer as well
Ultimately, you will need to do some data logging to be sure. There is no rich "sound" -- that's a new one! OFT can help you diagnose it, but so can a $10 OBDII reader with Torque.
Perrin's intake was designed to run perfectly fine without a tune, and catbacks have virtually no effect when NA. Your parts won't cause issues if they're correctly installed. Make sure your intake install didn't create a vacuum leak, and make sure oil hasn't slung onto the MAF.
#9 | |
My .02. Get an OFT and a 4.88 FD
1. OFT and Ebay extension cable with on/off switch. 2. 4.88 Final Drive The OFT costs $499, or less if you buy it used. The 4.88 FD costs $238.70 for the gears alone, (Weir Performance), and the rebuild parts can run from $50 to $500, depending on if the bearings need replaced or not. Labor is usually from $200 - $500 depending on the shop, and whether or not you remove/install the pumpkin yourself. The FD is the absolute cheapest power mod you can do to your car without affecting emissions. The speedometer is unaffected, speed is measured at the wheels. The transmission acts like it was always meant to be geared this way. It takes the load off the engine and trans, and puts it where it belongs, on the axles and tires. A 4.88 FD really makes this car move like it's supposed to. I bought a second rear carrier to put my 4.88 FD in, so I can switch back to my 4.10 for road trips. I also have slightly taller tires, (225-45-17 Conti extreme contacts) for better grip and a better ride, and a 4.88 FD compensates for this.
#10 | |
Still 17!
Drives: 2014 Silver BRZ Limited
'14 BRZ LIMITED-OFT (W.W. TUNED)-PERRIN-K&N-WHITELINE-DIODE DYNAMICS-GRIMMSPEED-REXSPEED-FT86-TAPTAP-OLM-GOODYEAR-OSRAM-WEIR-ENKEI-TOMEI EL
#11 | |
I don't have mine in yet. I had the gears in once before, but changed to a 4.30 to get better mileage. Now I don't need the mileage anymore, so I bought a second rear carrier, which is sitting in my trailer till Tuesday, when the shop opens back up again. I'll be swapping out pumpkins in my driveway, once I get it back. When I had mine in before, it whined, but I could spin rubber in three gears before the TC kicked in.
#12 | |
Drives: Toyota 86 GTS
There are others who've had nothing but problems with the 4.88 too. |
#13 | |
#14 |
I'll be installing a built 4.88 from Spencer soon, curious to see how that'll go.
| Break-in for Auto transmission? | djmm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 07-13-2014 01:46 AM |
| Kits for auto transmission FR-S? | Sparda29 | Forced Induction | 14 | 06-27-2013 12:34 PM |
| Auto transmission, really that slow? | husker741 | Engine, Exhaust, Transmission | 82 | 03-22-2013 11:29 PM |
| Replace auto transmission at 60k? | supramkivtt2jz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 03-09-2013 06:20 AM |
| WRB Premium BRZ Auto. Transmission Available! | ShoShin | BRZ First-Gen (2012+) — General Topics | 1 | 11-16-2012 07:25 PM |
