Old 06-21-2013, 11:38 PM   #1
Sparda29
Kits for auto transmission FR-S?
My knowledge on this is really weak. Are most of the super charger/turbo charger kits available for the FR-S available on the auto transmission platform? If so which ones? Thanks.
Sparda29 is offline   Reply With Quote
Old 06-21-2013, 11:42 PM   #2
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I have yet to see a transmission-specific FI kit.
campy is offline   Reply With Quote
Old 06-21-2013, 11:43 PM   #3
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
I assume the only difference would be the tune
Perihelion is offline   Reply With Quote
Old 06-21-2013, 11:46 PM   #4
Ny Brz
Hella Flush
Ny Brz's Avatar
Interested to see the limitations on the auto trans.
Ny Brz is offline   Reply With Quote
Old 06-22-2013, 12:31 AM   #5
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
the difference is in the exhaust piping it has to be at a different angle to cope for the wider transmission, 450-500 whp has been put through the auto without issue there are kits that accommodate for the spacing but i dont know which off the top of my head
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 06-22-2013, 01:04 AM   #6
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I was under the impression that the 604 hp full blown was a auto.. Am I wrong.. I thought they only had a auto for testing.. But again.. I could be wrong
Gixxersixxerman is offline   Reply With Quote
Old 06-22-2013, 01:58 AM   #7
PSJohnDoe
According to Vortech's site, their supercharger is for MT only...
Complete Systems (Manual Transmission Only) Shipping Now
Complete systems include a calibration upgrade and all necessary fuel components to boost your FR-S/BRZ to 294HP and 210 lb/ft torque with 9PSI at the factory redline. This includes a replacement MAP sensor and Ecutek programmer to re-flash the ECU with a safe, custom Vortech calibration for 91-octane fuel. Complete systems are currently available for manual transmission vehicles only. Calibration for automatic vehicles is under development.
http://www.vortechsuperchargers.com/page.php?id=30190
PSJohnDoe is offline   Reply With Quote
Old 06-22-2013, 02:16 AM   #8
415FRS
Drives: Red SCion FRS
That is because they only have tune for MT now on their complete kit. They are working on AT tune. I have vortech tuner kit running on my AT FRS now. It is the same kit for MT and AT , just the tunes are diff
Sent from my HTC One using Tapatalk 2
415FRS is offline   Reply With Quote
Old 06-22-2013, 02:37 AM   #9
PSJohnDoe
Good to know. I want to hear how the AT does with that extra power over time. There are plenty of MT upgrades to deal with the extra power, I don't think I've heard of anything for the AT (for the transmission itself, not that nothing works with AT).
Old 06-22-2013, 05:42 AM   #10
Perihelion
Perihelion's Avatar
IIRC, a few of the kits were developed on an AT
Old 06-27-2013, 01:10 AM   #11
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Strength wise both units can hold up to the power of a mild bolt-on supercharger with ease.
Old 06-27-2013, 01:14 AM   #12
carbonBLUE
Reverse Burnouts
yeah there are autos with 400 whp on this forum so nothing to worry about if under 300 whp on supercharger
(wont forget you)
2011 Infiniti G37x
Old 06-27-2013, 05:38 AM   #13
Fast_Freddy
Drives: Passat
It appears that the 6AT in the 86 is much stronger than the 4AT in my XB2. Nonetheless my XB2 had no problem dealing with 250whp/wtq with nothing more than a radiator bypass/B&M 15K BTU cooler and M1 ATF in place of the high-mpg Toyota WS (watery shit). I logged over 60k miles and 20+ 1/4 mile runs on the trans with +100whp/wtq over stock.
Long story short... it's never a bad idea to add an aux ATF cooler when running a AT hard or pushing extra tq thru it. Also, like 0w20 motor oil, thin Dexron VI, Toyota WS, et al are much more for mpg than trans/engine longevity. For HD use I recommend slightly thicker ATF and either a aux ATF cooler or a radiator-bypass with aux ATF cooler with cold fluid bypass. Heat kills AT's.
Fast_Freddy is offline   Reply With Quote
Old 06-27-2013, 07:42 AM   #14
PineappleFriedRice
Truuu
PineappleFriedRice's Avatar
Drives: 2013 FRS, 88 EF Civic, 05 Matrix
FA20CLUB's turbo is has been installed with auto trans
Here is a post with a dyno graph comparing the 57trim version to the vortech sc
http://www.ft86club.com/forums/showthread.php?t=40046
GARRET .60 TRIM-UEL HEADERS-1150cc INJECTORS-DW FUEL PUMP-RACESENG CAM PLATE-PERRIN 3" CATBACK-ULTIMATE RACING 2.75 OP/FP-FBM CATCHCAN-SINGER 275AMP ALTERNATOR-MEGAN TRACK COILS-MEGAN F/R STRUTBARS-AXLE EXCHANGE ALUMINUM DRIVESHAFT-ACT 6 PUCK-ANARCHY MOTIVE SHIFTKNOB-XXR 535-HANKOOK VENTUS EVO V2-CS LIP KIT
Build Thread - FA20FAIL Archive
PineappleFriedRice is offline   Reply With Quote
Transmission swap: auto to manual... itdansharpe Engine, Exhaust, Transmission 39 02-12-2018 04:53 PM
Auto transmission, really that slow? husker741 Engine, Exhaust, Transmission 82 03-22-2013 11:29 PM
Replace auto transmission at 60k? supramkivtt2jz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 03-09-2013 06:20 AM
WRB Premium BRZ Auto. Transmission Available! ShoShin BRZ First-Gen (2012+) — General Topics 1 11-16-2012 07:25 PM
