Old 08-04-2016, 06:54 PM   #1
phrosty
How complicated is a diff install?
I've got a built pumpkin to install, and I'm wondering if I should give some business to a smaller shop or if it's an involved enough process that should go to a more established shop.
If anyone who's done it cares to comment, I'd appreciate it.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 08-04-2016, 08:16 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Know how to adjust backlash?
If you don't know how to, have a professional do it.
If you do, the install is quite easy.
-alex
Old 08-04-2016, 09:51 PM   #3
phrosty
-alex
final drive is already installed in diff, just need diff installed on car.
Old 08-04-2016, 10:11 PM   #4
mav1178
mav1178's Avatar
1) lift car
2) disconnect midpipe on exhaust
3) pry out axles (but not remove it out completely
4) drain oil (or do it earlier)
5) unbolt driveshaft, loosen diff bolts, etc
6) support it with transmission jack
7) remove bolts, and as you slowly lower it, keep both axles as level as possible so that it comes out evenly on both sides
8) reverse steps for diff install
If you have a lift but no transmission jack, you can also do it via supporting the diff on a cart or off the ground, but you have less room to work with.
I just swapped mine back to stock on Tuesday in about 30 minutes of work with a lift.
-alex
Old 10-17-2016, 11:50 PM   #5
KoolBRZ
KoolBRZ's Avatar
missing one very important step
1) lift car
-alex
When you put the axles in, make SURE the openings in the C-clips are facing down, otherwise you could hammer it into oblivion and it still won't go in. When it's right it will pop in with the heel of your hand, when it's wrong it won't go in with a 10 pound sledge.
If I say yes, will that make you think I understand?
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
OEM Diff Kregar Mid-Atlantic 1 07-12-2016 04:30 PM
Diff oil HLHachiRoku Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 04-17-2016 06:12 PM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 02:59 PM
AVO Rear Diff Anti-tramp Bushing Install Pix Infamous Performance DIY (Do-It-Yourself) Guides 2 09-29-2014 04:48 PM
