Old 08-03-2016, 09:33 AM   #1
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Autox pads
Looking for an autocross set up. Thinking about running hawk blues in the front and hawk black in the back like the spec Miatas run. Only problem is I can't find a set of blacks for the back of the brz not sure if they make black for our car. Any ideas or opinions. It'll be street and mountain driving more than anything.
tofurun is offline   Reply With Quote
Old 08-03-2016, 10:06 AM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Run the same pads f&r.
AX-6 have been really good to me. They can get noisy.
The Following 3 Users Say Thank You to cjd For This Useful Post:
CSG Mike (09-09-2016), strat61caster (08-03-2016), tofurun (08-03-2016)
Old 08-03-2016, 02:58 PM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Project Mu HC+ 800. Excellant initial bite when hot and cold. Great auto-x/DD pad.
strat61caster (08-04-2016)
Old 08-03-2016, 03:02 PM   #4
e1_griego
e1_griego's Avatar
Drives: Many
Blues and black for parking lots? No way.
Those need heat to work, and you won't get that at autox.
The stock pads work fine, maybe some stoptech sports if you want a bit of an upgrade.
e1_griego is offline   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
saj (08-03-2016)
Old 09-09-2016, 08:03 PM   #5
makesdrivingfunagain
I had the stock pads on for 130 autocross laps and half a dozen mountain runs. They worked well!! I just installed the TRD front and rear set. I will have to drive a bit more to have a more exhaustive commentary about them. But I did some mountain driving or canyon carving last week. They seemed to have more bite when warmed up. I have only had them installed a week or so. Usually for street (generally speaking) TRD is a pretty safe way to go. The TRD pads are for street and autocross and not open track as stated in their description. I autocross and street the car. This is my daily driver. I have driven a WRX with project MU and they worked great!!!
2013 FR-S, AT, Braille 15lb battery, 16x7 Wedsport SA15R w 205/55/16 Continental Extreme Contact Sport, TRD drop in airfilter, TRD spring and TRD swaybars, TRD exhaust, TRD Brake Pads,4:56gear, 2740lbs
makesdrivingfunagain is offline   Reply With Quote
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads and Fluid For DD/AutoX/Track Days/HPDE ToyoburuBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 07-23-2016 03:59 PM
Advice for DD/autox break pads kravi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 12-18-2015 03:26 PM
Removed Offer: (Carbotech AX6 AutoX Pads) Brzzee Brakes, Suspension, Chassis 2 12-10-2015 12:38 PM
Cobalt Friction XR4 rear pads (autoX or track pad) smbstyle Brakes, Suspension, Chassis 1 11-19-2013 12:01 PM
