Old 07-28-2013, 11:03 PM   #1
1Cor10:23
1Cor10:23's Avatar
Is the instrument panel slightly angled (or just me?)
Did a few searches for this from the web but the ambiguous phrasing might be making it difficult.
I've been driving my FR-S everyday for almost a week now and I just started to notice that the instrument display seems to be slightly angled so that it is best viewed from left of centre of the driver's seat. Makes the steering column look angled with it as well...
Anyone else see it or am I crazy?
Old 07-28-2013, 11:05 PM   #2
Obsidiank
10 Series Fanatic
Drives: Scion FR-S 10
u are cray cray
Obsidiank is offline   Reply With Quote
Old 07-28-2013, 11:35 PM   #3
1Cor10:23
1Cor10:23's Avatar
Originally Posted by Obsidiank View Post
u are cray cray
Anyone else care to chime in? I still totally see it, just want to see if it's an issue with my assembly...thanks.
Old 07-28-2013, 11:44 PM   #4
humfrz
Well, at my age ...... everything looks angled........
I'll "look" tomorrow and give you my reading
humfrz
I went and checked. Mine looks straight .... tonite at least ......
Old 07-28-2013, 11:59 PM   #5
Luis_GT
Haven't noticed it at all... and my FR-S is my DD...
Old 07-29-2013, 12:41 AM   #6
Tromatic
Hmm. I THINK the OP is correct. I didn't break out the measuring devices, but I do believe that there is a slight angle. The instruments (tach, speedo) seem to be aimed just ever-so slightly towards the center of the drivers seat. If you could look down from the top is would be easier.
Tromatic is offline   Reply With Quote
Old 07-29-2013, 12:51 AM   #7
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
you look at the analog speedo?
bkblitzed is offline   Reply With Quote
Old 07-29-2013, 12:59 AM   #8
Symmetrical
Symmetrical's Avatar
Drives: 2013 DGM BRZ Limited
^he said speedo
Symmetrical is offline   Reply With Quote
Old 07-29-2013, 01:34 AM   #9
Tromatic
Rarely. Just the tach, usually, and digital speed "speedo" if I need to be legal. The analog speedometer is useless. Too hard for you to understand we are talking about the instrument faces themselves?
Old 07-29-2013, 01:37 AM   #10
bkblitzed
is better than you
bkblitzed's Avatar
oo a little hostility i sense. To the op, nope idk what you're talking about. Mine is all straight.. But then again I dont really look at the cluster when i drive.
Old 07-29-2013, 10:42 PM   #11
1Cor10:23
1Cor10:23's Avatar
If you drop the steering wheel as low as it goes and then visually line up the rear edge with the steering wheel with the front edge of the instrument cluster, it becomes a bit more apparent.
Old 07-30-2013, 03:08 AM   #12
DIF
DIF's Avatar
Drives: FR-S in Firestorm, Katzkin, alpine
Maybe your instrument panel is perfectly straight, but the rest of your
car is misaligned!
DIF is offline   Reply With Quote
Old 07-30-2013, 12:34 PM   #13
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
I feel this too, I pull my steering at the closest and lowest setting.
gzpermadi is offline   Reply With Quote
Old 07-30-2013, 06:04 PM   #14
1Cor10:23
1Cor10:23's Avatar
Originally Posted by DIF View Post
Maybe your instrument panel is perfectly straight, but the rest of you car is misaligned!
I thought about this actually (i.e. driver's seat misaligned when bolted?)
I've found a supporter!
F/S: FR-S instrument cluster MissDeb Audio/Visual, Electronics, Infotainment, NAV 5 04-08-2014 04:02 PM
Subaru 85 pcs LED Instrument Panel Gauge JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 0 05-16-2013 09:22 AM
How to remove small instrument panel? boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 4 03-02-2013 04:07 PM
WTB: FRS instrument cluster jabbajaw99 Interior Parts (Incl. Lighting) 3 02-14-2013 01:31 PM
Really low profile angled USB extender for cup holder clearance? oldpueblo Electronics | Audio | NAV | Infotainment 4 11-28-2012 07:22 PM
