Drives: FR-S White - Smexy.
Tire Mismatching okay?
Hi! I wrote a thread the other day regarding best street tires.
My TPMS light jus recently flashed meaning I have to switch my tires out today. I ahve Ecsta 4X running in the front two tires while I have Ecsta 4X II running on the rear. (Previous owner did this) is it okay to run 4X II on the rear?? The tread pattern is similar but size of the tread patterns are different. Can anyone look into and tell me if it's okay for me to just buy 4X II? |
Drives: LR BRZ Limited
you can run different tire size, brand and specs front and rear. but its generally a rule of thumb to run matching tires in each axle. for front and rear.
Drives: FRS
is your tire really flat, as in there's a nail/object or it's leaking air? if it's just low on air but not leaking, then you can just refill it with air and the tpms light will go away.
tpms light just means low air (or missing sensor lol). not "buy tires right now".
Drives: 2014 FR-S Asphalt
What he said. TPMS light comes on at about 29PSI, just means pressure is low. Has absolutely nothing to do with tread wear.
nono my treads are like borderline 10%
yeah... I remember the rule of thumb, however the ecsta 4x ii and ecsta 4x both have the same pattern, the tread pattern are just slightly different. Would using 4xii fit the general rule of thumb as it is technically the same tire?
Drives: Subaru BRZ Limited
unless your tires are so bald that there is an actual hole in them, then they will still hold air.
The TPMS light has nothing to do with the tread depth. |
Drives: 2014 GT86
Tires so bald that cord wires stick out? And you daily drive like that on public roads? There are no rules for minimum acceptable thread depth there? :/
#10 |
There is, I just found out today though. :/ Gonna change it asap today. Basically in a couple hours, which is why I posted this up before I finish work haha
#11 |
Okay, well Im going off work in 15 minutes so I am just gonna bite the bullet and get the ecsta 4x II again since the wheels worked fine originally.
#12 |
[insert cool phrase here]
Drives: BRZ Premium
Well like others said there shouldn't be any problems. As long as you have brand A on the front and brand B on the rears that would be fine.
Having different tires on left and right sides, there will be issues. That's no good.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| Replace Only 1 Tire? / Spare Tire Question | chermo12 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 07-28-2015 01:44 PM |
| Tire Blown - Recommended Tire Repair Shop? | chermo12 | CANADA | 3 | 07-27-2015 11:20 AM |
| Tire compound vs Tire size | Dihudaxia | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-22-2015 10:55 AM |
| best tire pressure gauge (tire pressure question) | steveholt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 03-21-2015 10:27 PM |
| Dai Yoshihara's 2014 Falken Tire/Discount Tire Subaru BRZ FD Reveal | SnapOv3st3r | BRZ Photos, Videos, Wallpapers, Gallery Forum | 62 | 04-15-2014 02:26 PM |
