Old 07-28-2016, 02:54 PM   #1
hands0me
hands0me's Avatar
Drives: small red
Exclamation engine got weird sound
hi,did anyone have same issue?
my engine got weird sound when rpm 1200-1500
sound like screw missing or drop but cant find the problem
View My Video
any solution and suggest
thank
hands0me is offline   Reply With Quote
Old 07-28-2016, 03:08 PM   #2
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
I feel like you're yelling at me.
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
Old 07-28-2016, 03:18 PM   #3
FX86
just zoom out a little bit and it will look okay
Old 07-28-2016, 03:20 PM   #4
mixtape
Posts in the nude
mixtape's Avatar
Old 07-28-2016, 03:41 PM   #5
uRBAN_Metal
Drives: '13 BRZ
Sounds like flywheel chatter to me. If the sound goes away when you push in the clutch, then that's what it is. It's not an issue in that case.
Also, good lord with the formatting. Leave that shit alone.
uRBAN_Metal is offline   Reply With Quote
Old 07-28-2016, 04:46 PM   #6
extrashaky
Drives: 2014 BRZ Limited
This car makes a lot of weird noises, but for once that one doesn't sound normal to me. Maybe you ought to take it into the dealer.
Old 07-28-2016, 05:25 PM   #7
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Doesn't sound like flywheel chatter. Plus you would only hear that if you were releasing the clutch under load. I'm assuming he's in neutral if he has the hood popped with someone filming.
Seems a bit louder than the standard direct injection tapping.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
Old 07-28-2016, 05:52 PM   #8
humfrz
Sounds to me like a bearing in the alternator or A/C pump is going bad.
You may consider taking a long screwdriver, with your ear on the handle end, and placing it around to see if you can pinpoint where the sound is coming from.
humfrz
Old 07-28-2016, 08:59 PM   #9
stevesnj
stevesnj's Avatar
Sounds like a rocker arm is loose.
My 2016 Build thread
Old 07-28-2016, 10:36 PM   #10
BRZnut
Drives: BRZ DGM Limited
I have heard that on this forum before....one person found it to be the rocker arms, and another more recently a bad vacuum pump I believe.
Old 07-28-2016, 10:57 PM   #11
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
The throttle sound reminds me of old 4age. LOL
I dont remember rpm but u also get chatter sound when the fuel pump swaps... cant think of it atm but not all injectors are working/not working. Like at higher rpm. urgh
Packofcrows is offline   Reply With Quote
Old 07-28-2016, 11:01 PM   #12
Ultramaroon
not playing cards
Ultramaroon's Avatar
Beat me to it. OP, is it an automatic?
Old 07-28-2016, 11:27 PM   #13
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
what? I cant see you I already zoomed out
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
Old 07-29-2016, 04:20 PM   #14
stevesnj
stevesnj's Avatar
Weird sound over 60mph FRiSson Issues | Warranty | Recalls / TSB 23 03-05-2018 11:47 AM
weird noise sound coming around header area shern Issues | Warranty | Recalls / TSB 28 02-19-2016 07:39 PM
weird engine sound Stratoside Issues | Warranty | Recalls / TSB 52 01-13-2016 03:05 PM
Weird whiny sound and possibly crickets? brzzy Issues | Warranty | Recalls / TSB 7 11-20-2015 02:51 PM
This might sound weird mrha BRZ First-Gen (2012+) — General Topics 10 10-06-2012 06:06 AM
