Drives: 2015 fr-s
weird noise sound coming around header area
just bought a uel tsudo header i installed it and whenever i floor it i here a clutter type noise what could it be?
Drives: BRZ DGM Limited
can you record the noise so people can hear it?
Not Bаnned Anymore
Drives: Heavily Modified FRS
Remember aftermarket headers use a thinner metal so they make more NVH
Drives: 2015 fr-s
Drives: Subaru BRZ
Tsudo is a low quality knockoff brand. My money is on: you have an exhaust leak.
Drives: 2013 SWP BRZ
I have an OpenFlash Header and had the same type of noise. For me it was more of a fluttering/leaves rustling type noise. Someone above mentioned the thinner walls of the header which could be it. For me it was a combination of loose nuts/bolts...took several re-tightening and addition of thread locker to make sure it didn't come loose. I think it's good now but at lower RPMs it does make that sound slightly.
Just remember to re-tighten to spec because it can become loose after initial install due to hot/cold temps after running your car.
"Don't be a don'ter, do be a doer" - Johnny Wu
^^ Also, another thing. If it is loose like mine was, your data logger should tell you if you have a something like Open Flash Tablet or something similar because your parameters will be off.
| The Following User Says Thank You to ap5512 For This Useful Post: | shern (02-10-2016) |
Drives: 2015 fr-s
Thanks for the info man ill make sure to retighten everything to day! and yeah mine does sound like a fluttering the leaves noise! and yes i know tsudo is low quality but i took the risk to see if ill get a good one and it did all the welds look great and the collector looks decent so quality wis ill give it a 8/10
#9 | |
#10 |
Drives: 2015 fr-s
I feel like its the connection between the overripe and the collector ! I used the stock gaskets the connect to the block and i tighten everything really tight but like i said I feel like its the connection to the overripe
#11 |
Drives: Subaru BRZ
Use an OEM gasket and gasket maker / sealer on both ends. I'm highly betting you're having an issue where the flanges are not flush and its leaking.
| The Following User Says Thank You to SpectreRT For This Useful Post: | shern (02-10-2016) |
#12 | |
Drives: 2015 fr-s
if i can't find it ill just go down to toyota and buy one from them |
#13 | |
Drives: Subaru BRZ
Use the RTV Silicon Gasket Maker stuff as well. Thin layer on each side of the gasket. That'll be double sure no more leaks.
| The Following User Says Thank You to SpectreRT For This Useful Post: | shern (02-12-2016) |
#14 |
Drives: 2013 FRS 10 Series #2072 (6MT)
If Toyota doesn't have it, Subaru definitely will. Learned from experience.
If anything, I'd be caught dead smiling.
| The Following User Says Thank You to Jrohit For This Useful Post: | shern (02-12-2016) |
| Raspy header and weird noise | Scalzo | Engine, Exhaust, Transmission | 39 | 08-24-2020 07:40 PM |
| Weird Crinkling noise coming from center console | fitcious | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 03-20-2016 04:56 PM |
| Weird rattling noise in cabin coming from front left | Webster10 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 03-01-2016 04:44 PM |
| weird noise from clutch pedal area... | mongiamc10 | Issues | Warranty | Recalls / TSB | 5 | 08-08-2014 06:04 PM |
| Weird Noise??? | caradd | Issues | Warranty | Recalls / TSB | 3 | 11-01-2013 11:42 PM |
