Old 07-27-2016, 03:56 PM   #1
FTA_Dave
Drives: 2013 Frs, E46 Bmw
Premium and limited brake pads different?
Can anyone confirm the rear brake pads are actually different and interchangeable ? The dealer as well as online look up show two different part numbers for a 2013. This normally wouldn't be an issue other than I have a Frs and get employee prices at Subaru.
Thanks
FTA_Dave is offline   Reply With Quote
Old 07-27-2016, 04:58 PM   #2
MrsJames
So. Many. High-heels.
Drives: 2016 Halo FR-S
Do you really want to put the OEM pad back in?
MrsJames is offline   Reply With Quote
The Following User Says Thank You to MrsJames For This Useful Post:
shellslinger (07-27-2016)
Old 07-27-2016, 05:44 PM   #3
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Thanks
The pads are the same shape so they are definitely interchangeable although I can't comment specifically on the pad material, I doubt it's different too.
Lynxis is offline   Reply With Quote
Old 07-27-2016, 06:30 PM   #4
renfield90
The Stig's German cousin
Do they also show different part numbers for a 2014? Could be a superseded part number.
Old 07-27-2016, 07:05 PM   #5
FTA_Dave
There actually is a notable size difference when compared side by side. Oddly Toyota only has one part number. I went with the 000 which are larger.
Old 07-28-2016, 06:51 AM   #6
Dihudaxia
Drives: 86
There are actually 2 different sizes for rear brake pads, as there are 2 different rear brake configuration. I am not sure if N.America has the different sizes, but the rest of the world does. Here is the summary;
86 G Grade: 16' wheels, with solid (non-Vented) rear rotors
86 GT Grade: 17' wheels, with vented rear rotors
Now the brake pads for the G and the GT grades are different in size, and are NOT interchangeable. So do not order the wrong part number, or you might have a pad that cannot be used.
Dihudaxia is offline   Reply With Quote
Old 07-28-2016, 09:16 AM   #7
FTA_Dave
I don't think that we ever got the 16" wheels here. The larger pads fit perfectly and I assume that is the standard in North America. It is something to watch for at the dealer however as they list and stock both sets.
Old 07-28-2016, 10:05 AM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It kind of helps if OP disclosed what location the inquiry is being made in...
North America only had one brake configuration on all FRS/BRZ from 2013 - current. 2017 will (obviously) have the Performance Package upgrade as an option.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Nickosport (07-28-2016)
Old 07-28-2016, 11:38 AM   #9
mav1178
mav1178's Avatar
So basically what OP sees is this:
http://parts.subaru.com/a/Subaru_201...10-263-01.html
http://parts.subaru.com/p/Subaru_201...6696AG051.html
"This product fits 148 vehicle variants.
Subaru: 7 models, 148 variants between 2011 and 2017."
http://parts.subaru.com/p/Subaru_201...6696CA000.html
This product fits 18 vehicle variants.
Subaru: 1 models, 18 variants between 2013 and 2016.
What I can see is that this rear pad is identical to another rear pad found in other Subarus between 2011 and 2017. For whatever reason, they chose to create two different part numbers in their system.
If the size between these two parts is actually different, then Subaru has the wrong info listed. It won't be the first time it has happened...
Meh.
-alex
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Limited gets brake "upgrade" over Premium - Canada only? Sport-Tech BRZ First-Gen (2012+) — General Topics 25 05-15-2012 12:35 AM
