OFT 2/3 specs
I've searched Google, FT86 forums, even sent emails to Shiv; but I cannot find anything on the specs for the OFT headers.
Situation: I purchased the OFT3 headers with the slip-joint headers. The joint connecting the overpipe to the headers is leaking. Does anyone have the diameter of the joint before I go jacking my car up and measuring? I'm likely going to get some RTV, JBWeld, or an exhaust clamp to fix the problem. |
Drives: MY15 BRZ WRblue
I just put the OFH 3 on as well and suspect I have the same problem. Will need to confirm once I get the car up and do a soapy water test. The leak is small and datalogging doesn't show a leak (at least to my limited knowledge) so I'm assuming the leak is after the first gaskets.
I did not put any sealing paste between the pipes during install, so that might be the reason for the leak. I'm hoping that applying some paste and tightening will fix the issue. |
#3 | |
Drives: frs
| What are your specs? | crash.1340 | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 01-20-2014 09:14 PM |
| Need help on specs | TheSlickOne17 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-14-2013 07:12 PM |
| AC specs | choi0706 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 04-22-2013 09:24 AM |
| Do i need the specs for an alingment? | Pandle | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 03-15-2013 11:34 AM |
| Cam specs?? | brn12345 | Engine, Exhaust, Transmission | 6 | 11-12-2012 05:04 PM |
