Old 03-14-2013, 05:58 PM   #1
Pandle
Drives: CBS BRZ
Do i need the specs for an alingment?
I have eibach springs installed and ordered some front camber bolts which should be here soon. I've never had an alignment done before... Do i need to tell them how to set up my car or will they already know? Also is it correct that I'll only be getting the front done and not the back because the rear end is non adjustable?
Pandle is offline   Reply With Quote
Old 03-14-2013, 06:13 PM   #2
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
you can get rear camber bolt from whiteline.. and id probably get it aligned if you havent used it yet you get one free alignment from toyota if its an frs. idk about subaru.
DanoFA20 is offline   Reply With Quote
Old 03-14-2013, 07:50 PM   #3
polancd
Drives: a few
depending on where you go they might or might not have the stock specs on their machine. Its best to tell them how you want it set up. And like dano said you can get rear camber bolt or you can get adjustable lca.
polancd is offline   Reply With Quote
Old 03-15-2013, 11:34 AM   #4
Pandle
Drives: CBS BRZ
I did end up buying a pair of rear lcas yesterday. If I don't grt the factory specs (I've read they're not that great) what should I be going for with a dd? I wont be tracking the car anytime soon.
Cam specs?? brn12345 Engine, Exhaust, Transmission 6 11-12-2012 05:04 PM
Tow hook specs? mufasis BRZ First-Gen (2012+) — General Topics 15 10-21-2012 10:41 PM
Specs of red on Whiteout Chinadian Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 15 10-17-2012 09:47 PM
HELP! Asian Specs BRZ Lucky13 BRZ First-Gen (2012+) — General Topics 8 09-02-2012 08:26 AM
To those who keep comparing the FRS to another car on specs... Moto-P Scion FR-S / Toyota 86 GT86 General Forum 60 06-06-2012 08:39 AM
