Old 01-18-2014, 07:17 PM   #1
crash.1340
BRZ FNG
crash.1340's Avatar
Drives: 00 Civic LX/CWP or GBS BRZ someday
Post What are your specs?
I was speaking with a friend of mine earlier discussing computer builds and the components we each had. Out of curiosity, what are you running?
I have:
AMD Phenom II X4 @ 3.4GHz
Asus M4A88TD-V (EVO/USB3)
8GB DDR3 RAM (can't remember speed)
1TB Western Digital HDD (Sata6)
Sapphire/AMD Radeon HD7770 GHz Edition with 1GB GDDR5
ThermalTake 750W PSU
Cooler Master Centurion case (oldie but a goodie!)
Random Plextor and LG optical drives
Vizio 32" 720p TV for a main monitor
I use it to play Minecraft, Portal (1 and 2), A game called Beam.NG Drive, and a little startup that just got Greenlit by Valve/Steam called 'Crashtastic'.
What do you have?
crash.1340 is offline   Reply With Quote
The Following User Says Thank You to crash.1340 For This Useful Post:
ZionsWrath (01-18-2014)
Old 01-18-2014, 09:21 PM   #2
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Uh, it's something.
It won't run abadonware unless i turn on all the CPU's, all i could tell you.
The Following User Says Thank You to dem00n For This Useful Post:
Old 01-18-2014, 09:26 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Don't really remember, I built it like 3 years ago. Has served well thus far and I really only play SC2 on it so no need to upgrade until SC3 cums out in maybe 10 years lol
i5 2500
Radeon 6950 2 GB
8gb ram
SSD and HDD
Some Z87 motherboard
Some corsair case
Some 21" (i think lol) monitor
I'd share a photo but you will all think I'm an alcoholic it is surrounded in beer cans, last night was my day off.
Cost me like $1000 when I built it, that is the price range I try to stick with. My computer before that cost the same and it lasted me like 7 years, and just recently died after about 11 or 12 years. I only upgraded it because SC2 came out and it couldn't handle it on the single core processor
Old 01-18-2014, 09:32 PM   #4
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
AMD 8150
Asus fx990 formula
Asus matrix 7970 platinum
16GB ram corsair vengeance
Cosair h100
Cosair ax750
Velociraptor 500gb HDD
In a bitfenix shenobi case Name:  uploadfromtaptalk1390098763640.jpg
Sent from my SCH-I545 using Tapatalk
Fett4Real is offline   Reply With Quote
The Following User Says Thank You to Fett4Real For This Useful Post:
Old 01-18-2014, 09:39 PM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
lol that looks like the same case I have.
But I didn't go baller water cooler, just a standard 212
Old 01-18-2014, 09:42 PM   #6
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
It's a bitfenix case by performacepcs Name:  uploadfromtaptalk1390099324585.jpg
Old 01-18-2014, 09:47 PM   #7
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
6'1 asian male
bkblitzed is offline   Reply With Quote
The Following 2 Users Say Thank You to bkblitzed For This Useful Post:
sklimo (01-18-2014), ZionsWrath (01-20-2014)
Old 01-18-2014, 09:49 PM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
pics? 25/m/ny
S2R
Old 01-18-2014, 10:01 PM   #9
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I really need a new case. Mine has absolutely no cable management and is loud.
The case is one of the things I rarely upgrade.
i5 3550
16GB DDR3 G.Skill... don't remember which exactly
EVGA GTX 660Ti
Intel 520 series 180GB SSD
WD Blue 1TB 7200RPM
Asus P8Z77-V LK Motherboard
Whatever lame score
The Following User Says Thank You to Andrew025 For This Useful Post:
Old 01-18-2014, 10:04 PM   #10
dalli
dalli's Avatar
Drives: Toyota
gtx 260
i forgot my cpu name lol, i used to be big in this
but something like
phenom II x4 3 ghz
4 gig ram
had it since 2009, still going strong! and runs all recent games without hiccups
dalli is offline   Reply With Quote
The Following User Says Thank You to dalli For This Useful Post:
Old 01-18-2014, 10:51 PM   #11
Namuna
Namuna's Avatar
Intel i7 980 3.3GHz (OC'ed to 4.2GHz)
EVGA x58 SLI-3
Corsair H80i Water Cooler
12GB DDR3
2 x EVGA GTX 680 Classified
Antec Earthwatts 750W PSU
RAID 0 HD @ 1.5TB
RAID 0 SSD @ 250GB
Blu-ray Burner
Dell 32" @ 2560x1600
...Just fast enough for Facebook and emails!
Namuna is offline   Reply With Quote
Old 01-18-2014, 10:51 PM   #12
n2oinferno
Praise Helix!
n2oinferno's Avatar
Ancient 1st gen CM690 chassis
Corsair TX650 PSU
Asus P8P67 mobo
Intel i5 2500k CPU @ 4.5GHz
Antec Kuhler 620 in push/pull exhaust config
8GB G.Skill Sniper RAM
HD 6950 GPU on 6970 shaders/clocks
1TB WD Black HDD
60GB Crucial/Dataplex solid state cache
It's old now but it gets the job done.
The Following User Says Thank You to n2oinferno For This Useful Post:
Old 01-20-2014, 12:14 AM   #13
crash.1340
BRZ FNG
crash.1340's Avatar
i5 3550
EVGA GTX 660Ti
WD Blue 1TB 7200RPM
Whatever lame score
I'm with you on needing a new case. The original Centurion (http://www.newegg.com/Product/Produc...82E16811119068) has absolutely ZERO room for cable management and since my PSU isn't modular, I have no place to put the 10 4-pin molex plugs or the 2' cables they're attached to. SATA running all over the place. I think I would benefit from a second GPU too, running in Crossfire. Not sure if it's totally necessary though... Decisions, decisions.
And whilst you are coasting along with a 4235 PassMark score, the laptop I am typing this on scored a whopping 610. I guess that's what you get with an old Mobility 4250 paired with an Athlon II P340. My 8GB of DDR3 1333 helped though
Old 01-20-2014, 12:37 AM   #14
crash.1340
BRZ FNG
crash.1340's Avatar
EVGA x58 SLI-3
12GB DDR3
RAID 0 HD @ 1.5TB
RAID 0 SSD @ 250GB
Blu-ray Burner
What kind of FPS you getting on Facebook? I hear that's a pretty graphically intense game!
Need help on specs TheSlickOne17 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-14-2013 07:12 PM
AC specs choi0706 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 04-22-2013 09:24 AM
Cam specs?? brn12345 Engine, Exhaust, Transmission 6 11-12-2012 05:04 PM
Specs of red on Whiteout Chinadian Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 15 10-17-2012 09:47 PM
Aussie specs sneaky AUSTRALIA 7 03-14-2012 12:37 AM
