Old 07-15-2016, 04:57 PM   #1
ThisGuyRett
This Guy
ThisGuyRett's Avatar
Drives: 2015 Halo FR-S M/T
DRL Issue on Used 2015 FR-S
Hey guys. Just purchased a 2015 Halo FR-S w/ 13,000 on the ODO, from a local Subaru dealership.
I noticed that there are no DRL's on, while driving.
Correct me if I am wrong, but the DRL's should be standard on a 2015 model, right?
Any help is appreciated. Thanks in advance.
ThisGuyRett is offline   Reply With Quote
Old 07-15-2016, 05:07 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yup and they can be enabled or disabled by the dealer. Take it in and get them to active that setting for you. (not something you can do on your own)
Old 07-15-2016, 05:15 PM   #3
ThisGuyRett
This Guy
I thought so. I called Subaru today and asked and they had no clue what I was referring to. I do have a Toyota dealership relatively close, but I wonder if they would charge me since I did not purchase from them. Thank you for the input!
The Following User Says Thank You to ThisGuyRett For This Useful Post:
go_a_way1 (07-15-2016)
Old 07-15-2016, 05:16 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
No worries and I know for a fact it only takes like 3 minutes so don't let them charge you much if anything at all.
Old 07-15-2016, 05:32 PM   #5
FX86
there is no drl button on the brz, right?
i know on the fr-s it can be disabled via techstream
Old 07-15-2016, 06:36 PM   #6
ThisGuyRett
This Guy
That I am not sure of for the brz. Thanks for the info about techstream. I'll mention it tomorrow when I take it to the dealership.
Old 07-16-2016, 01:35 AM   #7
humfrz
Welcome to FR-S ownership ..........
You may wish to check the fuse for the DRL system.
It's a 10A fuse, in slot #5, in the fuse block, located under the dash.....
NOTE: There is a fuse puller along with some spare fuses in the main fuse block under the hood.
humfrz
Ultramaroon (07-16-2016)
Old 07-16-2016, 07:09 AM   #8
ThisGuyRett
This Guy
humfrz
I have checked it already. Fuse seems to be fine. Thank you for the advice though!
humfrz (07-16-2016)
Old 07-16-2016, 06:19 PM   #9
scirocco78
Drives: Scion FRS
You can also get an app for your phone called Carista and a blue tooth OBD2 dongle and do this yourself along with some other neat stuff.
Another thing to look out for is some people just unlpug the DRLs. The plug is behind a trap door on the belly pan under the car on the passenger side.
scirocco78 is offline   Reply With Quote
The Following User Says Thank You to scirocco78 For This Useful Post:
Old 07-16-2016, 06:42 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
+1 OP, that's a resistor to limit current. If you do find it unplugged, I strongly recommend cleaning both sides before reconnecting it.
Old 07-16-2016, 07:06 PM   #11
ThisGuyRett
This Guy
Will check it out and also check out the resistor. Thanks Guys!
Old 07-18-2016, 11:51 AM   #12
ThisGuyRett
This Guy
Stealership wants a 100 bucks to re-enable.
Sent from my SM-N920V using Tapatalk
Old 07-18-2016, 12:13 PM   #13
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
LOL well, buy a techstream copy on ebay, or Carista app ($9.99 for a week access) and bluetooth OBD2 and save some money...
Stealerships at their best.
Old 07-18-2016, 09:19 PM   #14
tCsonfrs
Drives: 10 Series FR-S #207
Sounds about right(I work at a dealership lol)
tCsonfrs is offline   Reply With Quote
GrimmSpeed Battery Tie Down 2015 FRS Fitment Issue ildylan Cosmetic Modification (Interior/Exterior/Lighting) 14 02-13-2017 11:21 AM
86EXPO 2015 Beers & Boxers August 14th, 2015 Events@Ptuning Mid-Atlantic 24 07-26-2016 11:18 AM
2015 Formula Drift Tech Day - 3/28/2015 yospeed Southern California 1 03-05-2015 03:10 PM
Aside from 2015 Acura NSX and Toyota Supra, what else in 2015? stockysnail Northwest 7 01-13-2015 02:30 AM
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 10:47 PM
