Old 04-17-2015, 12:51 AM   #1
ildylan
rolling over my sidewall
ildylan's Avatar
Drives: 15 FRS
GrimmSpeed Battery Tie Down 2015 FRS Fitment Issue
First and foremost, I'd like to thank Casey for being rather responsive and not just assuming I'm an idiot for not being able to put on their battery tie down.
What should be a 2second install turned into quite a curious frustration. I sold my 05 STI and got a 15 FRS and I tried to install my battery tie down, but it didn't fit. I tried switching orientations, tightening different sides first and to different levels, but nothing worked.
This evening I went to a friends house who owns a 13 BRZ with a GrimmSpeed battery tie down to compare the size of our j-hooks
Just to confirm our confirmation, he decided to try and do the install himself to see if I am just truly mechanically inept.
Anyone else experience the same issue? Can anyone else confirm fitment on their 15 FRS or BRZ?
ildylan is offline   Reply With Quote
Old 04-17-2015, 01:19 AM   #2
ryoma
ryoma's Avatar
you should be able to buy the older style battery hook for like 5 or 10 bucks from the dealership. it can't be THAT expensive, but then again they call them stealerships for a reason... lol.
I don't see a reason why the older style j hook wouldn't fit
Old 04-17-2015, 01:30 AM   #3
swarb
have you tried swapping the hooks?
Old 04-17-2015, 08:06 AM   #4
ildylan
ildylan's Avatar
Drives: 15 FRS
The back hook is short and stubby and shorter than the front hook.
Yea; I'm just going to go to the dealer.Plus, I get SCCA discount so hopefully the cost will be negligible.
Old 04-17-2015, 11:36 AM   #5
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Thanks for making this thread!
Does it fit when you flip the battery tie down around so the GrimmSpeed logo is facing out? It seems like the amount of difference in thread is about the same as the difference in the machined height from one side to the other.
And I know you're probably not around your buddy with the 13 BRZ anymore, but was the rear j hook the same length?
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following User Says Thank You to GrimmSpeed For This Useful Post:
NWFRS (07-19-2015)
Old 04-17-2015, 11:52 AM   #6
ildylan
ildylan's Avatar
Drives: 15 FRS
My pleasure. I did flip the tie down, but it did not help. Well, IIRC it helped a little but not enough threads to really grab onto for me to feel safe. Though, I could be remembering incorrectly now as I spent a frustrating 45min after confirming this trying to put on the Perrin Reverse Lockout with shitty instructions so my brain was kind of not thinking clearly.
I am not, and I did not check that. Perhaps I'll have to meet up for burger and a beer with him tonight to compare those just cause.
The Following User Says Thank You to ildylan For This Useful Post:
GrimmSpeed (04-17-2015)
Old 07-19-2015, 11:12 PM   #7
brzbrad
[||•]=(86)=[•||]
brzbrad's Avatar
Drives: 2014 BRZ Limited WRB
Don't know if you ever found a solution but to anyone else that runs into this problem, I found one way to solve it. I went to Home Depot and got a 1 inch "S hook". I hooked one half of it to the mounting point in the engine bay, and I hooked the other half to the "J hook" that connects to the battery tie down. I don't have the GrimmSpeed tie down, but in sure this will work with all of them because all it does is just extend the length of the J hook so it can be tightened. The only problem is the front J hook is now a little longer than the back one, but it can be cut down. Hope this helps!
brzbrad is offline   Reply With Quote
The Following 2 Users Say Thank You to brzbrad For This Useful Post:
ildylan (02-10-2017), wrh3 (02-10-2017)
Old 07-19-2015, 11:36 PM   #8
ildylan
ildylan's Avatar
Drives: 15 FRS
I went to Subaru to get a '13 BRZ Rear Battery Bolt (82161AG011), but it is exactly the same as what is on my car currently. Luckily they are only $1.65. When I go back for the other parts I ordered I'll have to see if any of the other models have longer J hooks and try that. Thanks for the idea though.
Old 02-10-2017, 01:02 PM   #9
wrh3
billswebspace.com
wrh3's Avatar
Drives: 2017 Alfa 4C, 2019 Fiat 124 Abarth
Wish I would have read this thread before picking up one of these for my 2016 FRS, no go with my Odyssey PC1400 (a little taller than OE)......may try the s hook solution (THANKS!)
Bill
BillsWebSpace.com
wrh3 is offline   Reply With Quote
The Following User Says Thank You to wrh3 For This Useful Post:
Old 02-10-2017, 01:41 PM   #10
ildylan
ildylan's Avatar
Drives: 15 FRS
I still have mine; probably someone hidden in my parent's garage at this point.
I have yet to find a solution... other than finding a buddy with a BRZ/FRS that you can swap hooks with.
@GrimmSpeed gotta any extra battery hooks hanging around?
Old 02-10-2017, 01:55 PM   #11
The J Hook is pretty generic, you can buy them at almost any autoparts store, in different lengths. Maybe you can just buy a new one the right length?
A quick search of Amazon showed them in 6", 8" and 10" lengths for under 5 bucks.
Old 02-10-2017, 02:20 PM   #12
ildylan
ildylan's Avatar
Drives: 15 FRS
As a guy who buys a shit ton of stuff on amazon I can't believe I haven't done that yet.
The Following 2 Users Say Thank You to ildylan For This Useful Post:
Dadhawk (02-10-2017), tCsonfrs (02-13-2017)
Old 02-10-2017, 09:34 PM   #13
wrh3
billswebspace.com
wrh3's Avatar
Your mileage may vary but as suggested by brzbrad I was able to use a small S-Hook from (http://www.homedepot.com/p/Crown-Bol...4714/203001547) Home Depot that lengthened the J-Hook enough to work.....time will tell if this is a viable long-term solution.
Bill
BillsWebSpace.com
Dadhawk (02-13-2017)
Old 02-13-2017, 11:32 AM   #14
GrimmSpeed
GrimmSpeed's Avatar
We don't unfortunately, and it looks like you've already located some generic J-hooks which should do you well after a little trimming.
However, we still haven't had another person contact us to complain that the J-hooks were too short, and it's been almost 2 years. It makes me wonder if maybe your car had a mis-manufactured j-hook installed from the factory. Either way, I'm glad you've got it sorted and the solution of an s-hook is pretty clever too.
Chase
Engineering
Grimmspeed Battery Tie Down - Limited Edition #20 of 200 digital_assassin Engine, Exhaust, Bolt-Ons 2 03-19-2014 02:52 PM
FS: Grimmspeed Limited Edition Oil cap & Battery Tie down 86_ZN6 Engine, Exhaust, Bolt-Ons 1 02-13-2014 11:38 AM
Grimmspeed license plate relocator fitment Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 5 10-21-2013 04:27 PM
FS Grimmspeed Oil Cap & Battery Tie Down, Cusco Catch Can Sutty Australia Classifieds 6 06-20-2013 03:37 AM
FS: Grimmspeed Oil cap and Battery Tie Down Lost Engine, Exhaust, Bolt-Ons 5 01-25-2013 10:34 AM
