Old 07-11-2016, 07:50 PM   #1
JDR86
JDR86's Avatar
Drives: FRs WhiteOut
Powwwwa Gains
I'm pretty sure there are many discussions out there about this but, I was planning on getting a OFT with some UEL and catback exhaust. Haven't really looked at the specifics yet. But I just want to see what kind of power gains have people gotten from just these 3 mods. Also if people have gotten any problems with this set up. I don't want to go FI because this is my daily and I just want a little bit more go. Not trying to break the bank either. I was hoping it will at least break that 200 whp and gain some torque also. Love the car but I just want a little bit more go.
JDR86 is offline   Reply With Quote
Old 07-11-2016, 08:20 PM   #2
Gunman
Drives: 2019 Mazda Miata RF
Wrong section, this is the classifieds.
Gunman is offline   Reply With Quote
Old 07-11-2016, 08:21 PM   #3
gramicci101
Off Topic
You'll get close to 200 with a UEL and OFT stage 2, but you won't break it. You'll be somewhere between 185-195. If 200 whp is your target, then look at the ACE CS400 with Delicious tune, or a PTuning header with their tune, and they'll get you right at the 200 whp line. You can also run flex fuel/E85 and that'll give you 200-220 whp, depending on other supporting mods.
If you're running a catless header, especially a UEL catless header, you need to be careful picking your catback, or it'll be louder than hell.
Edit: And moved. Thanks moderators.
Old 07-11-2016, 08:55 PM   #4
JDR86
JDR86's Avatar
Sorry about that. First time using this tap talk app.
Old 07-11-2016, 08:57 PM   #5
JDR86
JDR86's Avatar
And yeah forgot to add that I don't want a loud exhaust setup. I do want a little louder than the stock exhaust.
Old 07-11-2016, 09:19 PM   #6
gramicci101
Off Topic
A catless header makes that difficult. UEL headers have the traditional Subaru rumble. EL headers sound more like inline 4s and make more power. Keep your OEM front pipe, because it has a cat and a resonator. Pick a catback that has a resonator, like Perrin, which is one of the quieter exhausts. Cats remove rasp from the exhaust tone, resonators smooth it out and make it quieter. There's a sticky thread in the exhaust section with youtube videos of different exhaust setups to listen to.
Old 07-11-2016, 09:22 PM   #7
steve99
have a read here
http://www.ft86club.com/forums/showthread.php?t=81493
and maybe some of the links below
Old 07-13-2016, 01:28 AM   #8
JDR86
JDR86's Avatar
Powwwwa Gains
I also wanted to ask what should I get first? The OFT then the header then exhaust or ???
Old 07-13-2016, 01:35 AM   #9
gramicci101
Off Topic
Get the OFT first. You can flash stage 1 and get a little boost, but more importantly you'll have the ability to flash stage 2 as soon as you get the header. Otherwise you're driving around with a header and no tune, which works, but it's not optimal.
Then the header. Then the exhaust. Your header choice will affect how loud you go on the exhaust, and the header is where the power is made, get that before the exhaust.
Old 07-13-2016, 03:12 AM   #10
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Do you already have the car?
Old 07-13-2016, 07:37 AM   #11
JDR86
JDR86's Avatar
Yeah I've had it for almost 2 years now. Only thing I've done is just lowered on TRD springs and some lighter wheels. Other than that I have not touch any engine components at all.
Old 07-13-2016, 08:42 AM   #12
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Just want to add to this -- Not to disagree with above poster, but in most cases you'll find that resonator's sole job is to reduce rasp. With most true resonators you'll only see a ~10% decrease in volume. The cat will kill ugly rasp, but it also reduces volume more than you'd see with a resonator. You want at least one cat in your system for multiple reasons.
Just for clarity.
ajcarson11 is offline   Reply With Quote
Old 07-13-2016, 09:37 AM   #13
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
OFT then UEL then perrin resonated or Q300 catback.
Live with what you get, you won't hit 200whp.
If you have E85 available, get the delicious E85 tune kit with UEL headers.
The JDL,Tomei/Gruppe S, or Ace headers are great choices, the Ace headers will cost a lot more but you'll see more gains from them.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 07-13-2016, 10:59 AM   #14
nastynate88
nastynate88's Avatar
Drives: 2014 BRZ
If only there was a sticky thread at the top of the subforum with this sort of information... hmmmm
nastynate88 is offline   Reply With Quote
TRD CAI and Exhaust HP Gains tennisfreak Engine, Exhaust, Transmission 51 11-08-2016 08:30 PM
extractor gains Jamesbrz Engine, Exhaust, Transmission 0 01-31-2014 03:23 AM
Possible whp gains kjdd787 Engine, Exhaust, Transmission 59 01-02-2014 11:59 AM
Possible whp gains kjdd787 Engine, Exhaust, Transmission 0 12-26-2013 05:51 PM
ECU HP gains? ender2664 Engine, Exhaust, Transmission 45 03-31-2013 03:33 PM
