Old 07-06-2016, 04:33 PM   #1
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Broken wheel during autocross
[ame="https://www.youtube.com/watch?v=i--dVfsPgEk"]Wheel Breaks during Autox Event - YouTube[/ame]
Old 07-06-2016, 04:36 PM   #2
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I saw this same thing happen at Blytheville a few years ago.
IIRC, aftermarket wheels were rubbing brake calipers and the owner "shaved" down the back of the spokes for clearance.
Twinz is offline   Reply With Quote
Old 07-06-2016, 04:53 PM   #3
strat61caster
strat61caster's Avatar
I was about to say that it looks like the wheel didn't break but he broke the studs/forgot to tighten the lugs, went and checked the youtube comments before shooting my mouth off and lo and behold:
https://www.facebook.com/JP.virtue/p...57361802220001
This is why people pay lots of money for good wheels or only stick to the proven stuff.
ineedyourdiddly
The Following 5 Users Say Thank You to strat61caster For This Useful Post:
funwheeldrive (07-07-2016), Guff (07-07-2016), krayzie (07-06-2016), soulreapersteve (07-06-2016), Teseo (07-06-2016)
Old 07-06-2016, 05:17 PM   #4
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
^ This Wheel is Famous on Instagram right now (Insert don't purchase rep wheels comment)
VIP BRZ is offline   Reply With Quote
Old 07-06-2016, 05:37 PM   #5
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Sounds like the driver has allergies and was doing a lot of sneezing...
venturaII is offline   Reply With Quote
Old 07-06-2016, 05:50 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
Has anyone heard of a stock wheel breaking? Kind of a loaded question but genuinely curious.
mdm (07-06-2016)
Old 07-06-2016, 05:52 PM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
Varrstoen- fancy name, cheap quality.
The Following User Says Thank You to wbradley For This Useful Post:
Guff (07-07-2016)
Old 07-06-2016, 05:56 PM   #8
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
This happened up here too. Not the same wheel mfg, but literally broke in the same fashion. Scary to think if you were marshalling at the time.
drewbot is offline   Reply With Quote
Old 07-06-2016, 08:01 PM   #9
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Just to play devils advocate...
It could be bad metallurgy, a flaw in the manufacturing process. It's hard to find a wheel manufacturer that hasn't had a wheel fail in that way.
Also, what is the history of this wheel? Is it new? Is it used? How many miles did it rotate? What conditions does it live through?
There's so many possibilities of cause, and you could even analyze some of these with the left over contents.
The Following User Says Thank You to dem00n For This Useful Post:
wbradley (07-06-2016)
Old 07-06-2016, 08:38 PM   #10
strat61caster
^^^ Focus ST is not easy on it's front wheels, lots of heat, lots of forces get put into them.
No wheel lasts forever, and the guy mentions in the comments he's in touch with the mfg and is optimistic they will take care of him with a replacement set.
ineedyourdiddly
Old 07-06-2016, 08:57 PM   #11
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
http://www.varrstoen.com/product/es3/
Reminds me of this:
krayzie is offline   Reply With Quote
Old 07-06-2016, 09:42 PM   #12
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Yup, Rota is currently going 'Yeeha! Pressure's off, boys! Make sure to share on your FB pages!'
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
Old 07-07-2016, 12:30 AM   #13
In counterpoint. If the good manufacturers that actually check metallurgy and have strict quality control programs can have wheels break (which they certainly do) then the odds sky rocket for some of these cheap manufactures. I personally know way to many people that had catastrophic failure from cheap wheels to believe the whole "they are just as good" theories. There are things you can cheap out on but wheels should never be one of them.
Ok let's hear from all the guys that will say how they never had an issue with their Walmart wheels.
DarkSunrise (07-07-2016), krayzie (07-07-2016), mdm (07-07-2016), new2subaru (07-07-2016), soulreapersteve (07-07-2016), strat61caster (07-07-2016)
Old 07-07-2016, 01:19 AM   #14
strat61caster
Anything that goes between you and the ground...
ineedyourdiddly
Tcoat (07-07-2016)
Help: Rubber Mud Flap/wheel house plate(?) Broken wanghaoyu6 BRZ First-Gen (2012+) — General Topics 7 06-29-2020 09:56 PM
Changed clutch and wheel studs and all hell has broken loose csmith171 Engine, Exhaust, Transmission 9 07-06-2016 05:38 PM
How to prevent broken wheel stud vincelive123 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 01-11-2016 07:21 PM
broken wheel studs Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-06-2012 12:47 AM
Broken Wheel Nut on new rims GC GTS Aero Kit Issues | Warranty | Recalls / TSB 38 10-08-2012 10:15 AM
