Drives: 2013 FRS
Changed clutch and wheel studs and all hell has broken loose
A couple weeks back I changed my clutch and flywheel as well as my wheel studs and now I am getting codes for the transmission speed sensors, right front speed sensor, left rear, low voltage, and the car is in limp mode with the cel traction control and abs lights all on. I double checked all the sensors and everything is plugged in... what the hell is going on??
Drives: WRB Subaru BRZ Limited 6MT
Did you check the relevant fuses?
Project Shadow
Drives: 2015 BRZ Limited 6MT
holy hell in a hand basket.....check the ABS rings and unplug and clean connectors and plug it all back in to see if that works. And check what theadmiral976 said, something has to of been missed or changed to have all of it go haywire. I bet it's something simple and small too.
Drives: frs
Ha, auto's
not playing cards
Exactly what codes did you get? Did you remove or mess with the wheel speed sensors? There are no speed sensors in the manual transmission.
Did you mess with the crankshaft position sensor plate when you swapped flywheels? I don't see how it's possible but I hear people have screwed up the installation.
#6 | |
Drives: 2014 SWP BRZ, MT
Specific codes will definitely help. Did you remove the hubs to change the studs? The front hubs have a protective backplate that shields the backside of the sensor. The rear axle has a plate that does the same. If you pulled the hub without removing the sensor from the upright first it's very likely you damaged or snapped the sensor. Not sure about the other problems until we get the codes.
The answer is racecar. Always.
not playing cards
Wow, I would say that's Subaru's fault for keying it symmetrically. A slight offset would keep the bolt holes from lining up. Thanks. I'll keep an eye out for that in the future.
It's funny because I knew immediately after watching the ECU readout and it showing 0 rpm. The motor was out of the car and on the hoist from a build and I placed it with the teeth facing me, and didn't think anything of it. It didn't occur to me until it was all buttoned up and didn't work. The plate usually stays somewhat put if you don't need to remove it. But yes certainly wouldn't have been hard to make it keyed one way.
Drives: 2013 FRS
It was all just a broken left rear abs sensor haha. All is well at the moment.
#10 |
That Guy
Drives: Fast and Hard
Scaring us here haha
"Knowledge will give you power, but character respect.."
DD: 2007 Suzuki Sv650 Weekend Car: 1969 Chevelle Summer/Weekend Car: 2014 BRZ |
| Subaru field engineer says OEM wheel studs only good for 75 to 80 wheel changes | Pat | Tracking / Autocross / HPDE / Drifting | 86 | 07-16-2021 10:50 AM |
| stiffer clutch= broken Clutch fork | KAR | Engine, Exhaust, Transmission | 1 | 04-25-2016 05:31 AM |
| Clutch Fork Broken | rick s | Issues | Warranty | Recalls / TSB | 8 | 08-27-2015 01:49 PM |
| Broken Clutch HPDE | yzarc0g | Tracking / Autocross / HPDE / Drifting | 0 | 06-25-2014 08:33 PM |
| broken wheel studs | Matt Andrews | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 11-06-2012 12:47 AM |
