Break in for new short block? ECU?
My short block and ECU are being replaced under warranty. Should I be going easy on it per the manual? Does that only apply to new cars presumably broken in from the factory and not my brand new short block? Or should I abuse it to"teach" the ECU to run more aggressive trims during that critical <100 mile period when it will permanently save driving habit information with it's "handshake" with the engine? I'll be tuning on e85/flex fuel after I'm confident the dealership didn't fuck anything up
#2 |
New short block? Break it in like a new car.
| The Following User Says Thank You to CSG Mike For This Useful Post: | humfrz (07-05-2016) |
#3 |
#4 |
Drives: Full race 4cyl boxer
What happened to the first engine?
#5 |
Spun a bearing> contaminated oil> clogged cam control valves> somehow damaged the cam gear???> ecu stuck thinking the cams don't have enough oil pressure even though they do. There weren't any noticeable symptoms indicating the engine was damaged except I noticed a ticking/tapping noise. But these cars make all kinds of noises so I don't know when it happened. I've never over revved or boosted so I blame mechanical failure. Apparently quite a few 2013s spun bearings according to Tcoat
#6 |
Drives: 15 BRZ LTD, 05 FXT
Depends on what engine break in philosophy you subscribe to.
Personally, I subscribe to break in oil and gentle driving up to temp, then lots of 100% load varied driving for 100 miles or so, changing the oil, THEN following OEM break in procedures. Gotta seat those rings!
#7 | |
#8 | |
I've got 80k on the built motor on my forester by giving it as close to 100% load as I could give it, as long as I could give it with BP break in oil.
#9 | |
#10 |
Drives: 13 frs red
My 13frs has 3k on entire new motor. Original spun bearing and was replaced with a short block which failed due to bad assembly. Toyota stood by it though. New motor has much less valvetrain noise than the original.
| WTB: Used Short or Long Block | NotSoJDM | Want-To-Buy Requests | 2 | 12-28-2017 12:51 AM |
| FA short block | xwd | Want-To-Buy Requests | 0 | 03-07-2015 12:42 PM |
| WTB: FA20 Long Block/Short Block blown/running | The Racers Line | Engine, Exhaust, Bolt-Ons | 7 | 07-29-2014 02:26 AM |
| WTB: FA20 Short Block or Blown Long Block | The Racers Line | Want-To-Buy Requests | 1 | 06-29-2014 06:21 PM |
| WTB: short block or long block | DOTman05 | Engine, Exhaust, Bolt-Ons | 2 | 07-14-2013 07:48 AM |
