Old 07-05-2016, 01:32 AM   #1
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Shock/damper question
Currently, i am running 8k/8k spring rate front and rear.
My coilover have 24 adjustable clicks. currently running 3 clicks from very soft "front" and 3 clicks from very soft (rear).
Sadly, while i was running around the mountain today. I felt the car is a bit floaty (maybe due to the spring rate), and seems like the front wont grip as much, and the rear about to slide during corner. Also, i feel less response from steering wheel to the wheel.
P.S 4 tires are 9/10 new -2 camber front , -1.5 camber rear
I mean the grip still great when running high speed corner on road and freeway, but not on windy mountain road.
I thought soften the damper/shock can provide more grip on low speed mountain road.
So what is the problem?
Thanks
FR-Sky is offline   Reply With Quote
Old 07-05-2016, 01:35 AM   #2
e1_griego
e1_griego's Avatar
Drives: Many
What shocks? what tires?
e1_griego is online now   Reply With Quote
Old 07-05-2016, 01:38 AM   #3
FR-Sky
FR-Sky's Avatar
Fortune auto prime coilover
MPSS 225/45/17
Old 07-05-2016, 05:48 AM   #4
Tor
Tor's Avatar
Drives: Toyota GT86
The car is probably underdamped with set to almost full soft. Setting it so soft is the girlfriend-friendly setting, not any useful setting for any kind of performance driving.
Tor is offline   Reply With Quote
The Following 2 Users Say Thank You to Tor For This Useful Post:
FR-Sky (07-05-2016), justatroll (07-06-2016)
Old 07-05-2016, 06:56 AM   #5
D_Thissen
D_Thissen's Avatar
^^ Thats my guess also. Maybe set the dampers to some where in the middle (or what ever Fortune Auto suggests) and see if that helps. Those spring rates should be fine.
The Following 2 Users Say Thank You to D_Thissen For This Useful Post:
drewbot (07-06-2016), FR-Sky (07-05-2016)
Old 07-05-2016, 10:38 AM   #6
MeisterR
MeisterR's Avatar
Drives: BNR32
For a road car, the 8/8 I think is quite a bit too stiff.
Chances are the damping is too soft, it is better to have slightly softer springs rate so you can run a stiffer damper adjustments.
Because having the stiffer adjustments is what going to help load your tires and give you that steering response you want.
Jerrick
MeisterR is offline   Reply With Quote
The Following User Says Thank You to MeisterR For This Useful Post:
FR-Sky (07-05-2016)
Old 07-05-2016, 11:11 AM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
That -1.5 camber in the rear isn't doing anything to help rear grip either. Set it down to -1. What sway bars are you using?
Old 07-05-2016, 11:33 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
-1.5 is going to give more lateral grip at the rear than -1, and still nowhere near the point where you start to lose longitudinal grip (which is not a huge issue anyway for a stock-hp 86). For a performance street setup, I would want at least -1.5 at all four corners, preferably more up front. I think you're good with -2 front/-1.5 rear. I run -3 front -2 rear on the street/sometimes-tracked FD fwiw...
Regarding damper settings, usually you set by counting clicks from full stiff. So you're at 21 clicks out, with 24 total. Beyond some number of clicks the dampers are likely effectively at "full soft" anyway. If it feels soft, try 10 clicks out and see how that works out. Go from there...
Lack of front end grip: Square spring rates with struts up front with a motion ratio on the order of 0.95, and multilink rear with a motion ratio more like 0.75, with 8/8 springs, your wheel rates are something like 7.2 front, 4.5 rear or 61.5F/38.5R. Seems a bit front-stiffness biased to me, especially for a car without a lot of power. That said, a lot of aftermarket coils for the 86 come with same-rate springs front/rear. But it doesn't seem quite right to me. Might try either softer front springs and/or stiffer rear for more front grip. What toe are you running?
The Following 3 Users Say Thank You to ZDan For This Useful Post:
DarkSunrise (07-05-2016), FR-Sky (07-05-2016), wparsons (07-05-2016)
Old 07-05-2016, 11:43 AM   #9
wparsons
wparsons's Avatar
Thanks
So less front AND rear grip, plus feels vague at the steering wheel. What are your tire pressures like?
What all was changed since the last time you drove it like this?
flickr
Old 07-05-2016, 11:44 AM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The problem is that you have no idea what the dampers are capable of. Without them being properly dyno'd and matched to the springs mounted, it's impossible to get proper handling out of the box.
This is why high-end coilovers often cost more, because they are better matched up from the factory out of the box. And it should also be noted that more adjustments doesn't mean they all work well. I've seen 32-way adjustable coilovers with clicks 10-25 all doing virtually nothing on a dyno.
-alex
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
strat61caster (07-05-2016), totopo (07-06-2016), wparsons (07-05-2016)
Old 07-05-2016, 12:24 PM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
Also, i feel less response from steering wheel to the wheel.low speed mountain road.
MPSS 225/45/17
How long have you had these on the car? How old are they (date on sidewall)?
I had a pretty miserable experience with the MPSSs on my FD. Initially, they were fine. Great grip on the street and acceptable at the track (if not up to "Extreme Perf" tire standards). But after about a year and a half, they lost all grip on the street. No front end grip, dangerously little rear grip and worse, at the limit the back end would come WAY out. Practically zero sliding grip. Tires had one track day and ~15k miles on them, Barely less than half tread depth remaining in back and more than half up front. But they were TOAST. Seriously, they felt like a late 20th century "performance" tire that had been heat-cycled to death.
After puzzling over setup, I got new tires (B'stone RE71R) and all is well again.
I know people LOVE MPSS tires, but to me they were initially fine, but ultimately utter crap for grip, to the point of being dangerous. Somthing to consider...
Old 07-05-2016, 12:36 PM   #12
Icecreamtruk
Drives: Track preped NA FRS
Exactly my experience with the MPSS. I think they get toasted by the heat. Mine go from cold (very little grip) to greasy (even less grip) in a single lap. Needless to say I dont run them anymore on track (still my street tire, around 60% thread left).
The Following User Says Thank You to Icecreamtruk For This Useful Post:
FR-Sky (07-05-2016)
Old 07-05-2016, 12:57 PM   #13
FR-Sky
FR-Sky's Avatar
running 0 toe front and rear.
So i should try soft damper front and stiffer damper rear? Since i cant change the coilover anytime soon...
Wouldnt stiffer rear will slide during corners?
Many thanks!
Old 07-05-2016, 01:02 PM   #14
FR-Sky
FR-Sky's Avatar
My tire pressure was 32 after heat, i figure that would provide more grip since i was going for mountain road..but i guess not..
The only thing change was some what 7 to 9 clicks from soft on the dampers.
I mean still OK doing high speed freeway and local turns. I can feel the car and body roll,but just not on mountain road.
What can you learn from a shock dyno chart? Or shock dyno 101 Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 03-01-2016 07:40 AM
FRS VS BRZ Damper (strut) kilohercas FR-S / BRZ vs.... 1 09-24-2015 03:19 AM
Koni Sport Shock Question FRSFirestorm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-12-2013 01:43 PM
Hood Shock Carbon Fiber Damper Set? Mo707 Cosmetic Modification (Interior/Exterior/Lighting) 24 08-10-2012 02:31 AM
GReddy releasing carbon fiber hood damper/shock set! Deebeaux Cosmetic Modification (Interior/Exterior/Lighting) 13 08-04-2012 05:22 PM
