Old 06-16-2013, 07:13 PM   #1
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Koni Sport Shock Question
Maybe a stupid question and I've done a bit of web searching but can't come up with an answer. I've never had adjustable shocks on a 4 wheel vehicle but I've ridden bikes for most of my life. Shocks on sport bikes typically come with 2 adjustments, one for rebound and one for compression. Obviously independently adjusted.
There is only one adjustment point on the Koni's. Does it adjust the shock rebound, the compression or both?
TIA for any input.
FRSFirestorm is offline   Reply With Quote
Old 06-16-2013, 09:50 PM   #2
spdfreak
spdfreak's Avatar
Drives: GBS BRZ Limited
I can't say for sure but my guess is that it adjusts rebound since that's what it adjusted on the Koni yellows I put on my mazda.
spdfreak is offline   Reply With Quote
Old 06-16-2013, 11:36 PM   #3
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
I believe all Koni yellows only have rebound adjustment.
G_Ride is offline   Reply With Quote
Old 06-17-2013, 12:09 AM   #4
xwd
Yes they have a preset compression and the adjuster controls rebound. There is a very slight affect on compression but not much.
Old 06-17-2013, 02:11 AM   #5
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I have them and they are rebound. Max soft is a great street comfortable ride, better than stock when paired with the RCE Yellow springs that I also have even though it's much stiffer. Putting them at full firm is not comfortable but would probably be great at the track, which I'll get to try in August.
stockysnail is offline   Reply With Quote
Old 06-17-2013, 08:17 AM   #6
FRSFirestorm
Red is Fastest
Thanks guys, I have them paired with Eibach Pro's and currently set mid range of adjustment. I honestly can't tell much difference in ride from stock even set here. I'd had the springs with OEM shocks on for about a month.
Old 06-17-2013, 10:17 PM   #7
nemes
Drives: scion frs, corolla, gsxr750
@FRSFirestorm how low was the results, front and rear? I have koni yellows too but am looking for the right springs to get low as possible.
nemes is offline   Reply With Quote
Old 06-17-2013, 11:24 PM   #8
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
Koni Sports are rebound adjustable only. They are also still on sale for $615 a set through 6/28, after that they go back up to over $750 a set, so if you want a set act fast because it'd suck to pay some $140 more for the same shocks because you waited too long.
I've got plenty in stock, shipping is about $20 most anywhere in the USA.
Sam Strano is offline   Reply With Quote
Old 06-18-2013, 08:26 AM   #9
FRSFirestorm
Red is Fastest
I honestly haven't taken any measurements. I'd say its real close to the 1" everyone reports.
Old 07-12-2013, 01:43 PM   #10
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
Most single adjustable shocks, whether they are coilovers or not, only adjust rebound.
Corner3garage is offline   Reply With Quote
KONI SHOCK VALUE SALE limited time only @ Circuit Motorsports! Lower prices all Koni Circuit Motorsports Brakes, Suspension, Chassis 115 08-30-2013 10:29 AM
Trade your BRZ fender insert for FRS insert? Whiteout/Satin white pearl jacobzking Exterior Parts (Aero, Lighting, Etc.) 0 06-05-2013 12:15 AM
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 05:48 PM
Adjustion compression on a Koni 8612 insert? Evil86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 03-05-2013 05:01 PM
Lutz Performance | STANCE (Super Sport & Supe Sport+) coilovers Diego@lutzperformance Brakes, Suspension, Chassis 1 10-04-2012 01:43 PM
