Drives: BRZ Limited
I want to hardwire a radar detector, but i need to find a fuse that would be powered only when ignition is on and would be safe to do so. Any tips ?
![]() 16 BRZ Limited |
accessory fuse. you have two cigarette adapter ports so find one that you don't use (like the one in the glovebox) and figure out which fuse it is (there are 2) and tap into that. picking any accessory fuse is probably fine since the radar detector won't draw too many amps but it doesn't hurt to be safe just in case you want to charge an ipad on the same port or something that uses a lot of power.
or you can just plug into the cigarette port into the glovebox and hide the wiring. that's what I did for my dashcam and it's easily reversible. tapping a fuse isn't that reversible unless you do an add-a-fuse. some people also tap right behind their auto dimming mirror too.
Garage:
2013 BRZ Limited 6MT - Galaxy Blue 1994 Ford Probe GT 5MT - Red(some would argue pink) 1969 Mustang Fastback 4MT - Royal Maroon |
| Tags |
| hardwire, radar, radar detector |
| Hot fuse tap - Which fuse? | cgrey | Electronics | Audio | NAV | Infotainment | 9 | 09-17-2016 07:24 PM |
| Fuse box. | Chen | Northwest | 4 | 01-19-2015 03:51 PM |
| Best fuse to tap that is hot with car off? | Frs32907 | Electronics | Audio | NAV | Infotainment | 0 | 08-30-2014 10:11 AM |
| Where to FUSE Tap for fog lights? | IgnitionGundam | Electronics | Audio | NAV | Infotainment | 1 | 04-24-2014 10:19 PM |
| Fuse Box | beagoodruslan | Electronics | Audio | NAV | Infotainment | 0 | 04-19-2014 11:31 PM |
