Old 07-04-2016, 09:51 AM   #1
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Factory heads?
I'm seeing a lot of builds building just the short block and using head studs. How rough and tough is the factory valve springs?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 07-04-2016, 10:01 AM   #2
Dream20b
Y u do dis?
Haven't done any research on this but...
I haven't seen any of these broken yet, so I assume fairly strong.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 07-04-2016, 10:20 AM   #3
gramicci101
Off Topic
I know Full Blown has stage 1-3 head packages (hehe), so the need has been identified. They also push 700+ hp though, so maybe the OEM head is only an issue at those levels.
@FullBlown, at what level did the head become an issue?
Old 07-04-2016, 10:30 AM   #4
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Doing valve springs helps keep the rockers from shooting out the valve cover. We do them on every built motor and check that the lash is correct
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Kris86 (02-21-2017)
Old 07-04-2016, 01:11 PM   #5
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
the factory springs are far too light for any reasonable amount of boost
if you're rebuilding the engine I'd swap them out for something heavier
Matt@Cosworth is offline   Reply With Quote
The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post:
FRS Justin (07-04-2016), Kris86 (02-21-2017)
Old 07-04-2016, 01:58 PM   #6
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
[QUOTE=gramicci101;2696432]I know Full Blown has stage 1-3 head packages (hehe), so the need has been identified. They also push 700+ hp though, so maybe the OEM head is only an issue at those levels.
Head packages are a serious thing..... hehe
MS, CSCS, TSAC-F, CPT
Old 07-04-2016, 04:38 PM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
If going high power, a lot of people have swapped the valve springs. Some people have actually broken a spring. If you are 300 HP or less probably not needed in most cases,from what I have read.
Old 07-06-2016, 07:44 AM   #8
Matt@Cosworth
I agree with that - although the standard spring cover is so small that even a stock engine would benefit from a slightly heavier spring to help with over-rev's
my analysis showed a max safe rpm with the stock cam is 7800rpm....
admittedly a loss of valve control is something that you can often get away with for a while until the valve head falls off 10,000 cycles later
ajc209 (07-08-2016), Andew727 (07-07-2016)
Old 07-06-2016, 12:40 PM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
I was about to interject/ask about this mysterious relationship of valve spring rate to power but fortunately you came into the picture.
Does your BRZ still turn heads? Grimlock BRZ First-Gen (2012+) — General Topics 50 05-27-2014 02:29 PM
Wtb FA20 heads Wonderbar Want-To-Buy Requests 6 08-23-2013 08:38 AM
Heads Up BRZ Available In So Cal ZmZMWagon Southern California 17 06-18-2012 03:10 PM
