Drives: Late 2014 Subaru BRZ
Factory heads?
I'm seeing a lot of builds building just the short block and using head studs. How rough and tough is the factory valve springs?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#2 |
Y u do dis?
Haven't done any research on this but...
I haven't seen any of these broken yet, so I assume fairly strong.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#3 |
Off Topic
I know Full Blown has stage 1-3 head packages (hehe), so the need has been identified. They also push 700+ hp though, so maybe the OEM head is only an issue at those levels.
@FullBlown, at what level did the head become an issue? |
#4 |
Drives: 2JZ FRS
Doing valve springs helps keep the rockers from shooting out the valve cover. We do them on every built motor and check that the lash is correct
| The Following User Says Thank You to spitfire481 For This Useful Post: | Kris86 (02-21-2017) |
#5 |
Drives: blue - Cosworth SC stage 3.0
the factory springs are far too light for any reasonable amount of boost
if you're rebuilding the engine I'd swap them out for something heavier |
| The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post: | FRS Justin (07-04-2016), Kris86 (02-21-2017) |
#6 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
[QUOTE=gramicci101;2696432]I know Full Blown has stage 1-3 head packages (hehe), so the need has been identified. They also push 700+ hp though, so maybe the OEM head is only an issue at those levels.
Head packages are a serious thing..... hehe
#7 |
Sarcastic SOB
If going high power, a lot of people have swapped the valve springs. Some people have actually broken a spring. If you are 300 HP or less probably not needed in most cases,from what I have read.
#8 | |
my analysis showed a max safe rpm with the stock cam is 7800rpm.... admittedly a loss of valve control is something that you can often get away with for a while until the valve head falls off 10,000 cycles later |
#9 | |
| Does your BRZ still turn heads? | Grimlock | BRZ First-Gen (2012+) — General Topics | 50 | 05-27-2014 02:29 PM |
| Wtb FA20 heads | Wonderbar | Want-To-Buy Requests | 6 | 08-23-2013 08:38 AM |
| Heads Up BRZ Available In So Cal | ZmZMWagon | Southern California | 17 | 06-18-2012 03:10 PM |
