Old 06-23-2016, 11:33 PM   #1
Jrider
Jrider's Avatar
Drives: 2013 Silver BRZ
Day Trip MPG malfunction
So recently I noticed that the Trip MPG indicator is malfunctioning, it reads from 0-127 mpg up and down, all around. It never stays the way it used to. I understand that it will reach a high number and gradually go down, but this is all over the place. Has anyone else noticed this or had this problem?
The standard average MPG indicator is functioning normally.
I recently installed a Perrin CAI. Not sure if it was on the fritz prior to this.
Jrider is offline   Reply With Quote
Old 06-23-2016, 11:50 PM   #2
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
? That sounds normal. It read the instant how much u are steping on the gas.
if your foot isn't even on it it's gonna be into 100x.
Old 06-24-2016, 03:01 PM   #3
kuangxtc
Drives: 2013 DGM BRZ Limited
Yeah that's what it's supposed to do. It's an instant MPG reading, so if your foot is completely off the accelerator and you are going at a sufficient speed it will read 127 MPG. Likewise, if you are accelerating hard, your MPG reading will be very low, and if you are on a flat highway with cruise control you can expect the instant MPG to be relatively constant, will jump around a bit depending on incline/declines of the road.
kuangxtc is offline   Reply With Quote
Old 06-24-2016, 04:07 PM   #4
Two threads to ask the same question?
Old 06-24-2016, 04:47 PM   #5
iamjacob
insert witty quip here
Drives: 2016 Limited BRZ
I'm guessing the other thread told him that he's on the instant MPG and not the average MPG?
Press the MPG button a few times to cycle around to the other reading.
iamjacob is offline   Reply With Quote
Old 06-25-2016, 12:56 AM   #6
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Unplug the battery and re-plug it back in.
Packofcrows is offline   Reply With Quote
Old 06-26-2016, 12:14 AM   #7
Jrider
Jrider's Avatar
To answer all the above:
Since I am new to the thread I wasn't sure where to post the question. Like I stated in the original question, the average MPG is functioning normal. so by that logic I had already cycled through the options. I thought the question I asked was clear and to the point.
I disconnected the battery before I reached out to ask the question.
In the other thread I basically stated that I was wrong and I must have been expecting something to be going haywire since I had installed the CAI. I thanked everyone for their input. And now I will thank you for your input.
Cruise control malfunction totally Issues | Warranty | Recalls / TSB 20 02-26-2018 09:13 PM
P1604 Startability Malfunction Hempo Issues | Warranty | Recalls / TSB 3 04-15-2015 07:15 AM
Stock Radio Malfunction Re~Mix Electronics | Audio | NAV | Infotainment 7 01-02-2013 08:05 PM
BRZ temperature display malfunction percyng CANADA 7 10-24-2012 09:31 PM
First Malfunction? Ishii Motors Scion FR-S / Toyota 86 GT86 General Forum 6 06-09-2012 12:16 PM
