Old 01-02-2013, 12:00 PM   #1
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Stock Radio Malfunction
Hi all. Zero problems with the stock unit thus far, however I got in my car this morning and no sound was coming out of the speakers with either the am or fm setting on. (yes, the volume was turned up)
I tried a CD, USB, and my phone and all those played perfectly. Any suggestions as to what could be the issue? Hoping I get in my car this afternoon and everything is fine.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
Old 01-02-2013, 12:27 PM   #2
developer
Drives: BRZ Limited
It might be a little drastic but you could try pulling the battery cable off for 15 minutes and let the whole system reset. I remember someone else having success with doing the above on a head unit problem. Good luck and let us know.
developer is offline   Reply With Quote
Old 01-02-2013, 12:55 PM   #3
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
yea, i agree with @developer. i think a reset via battery disconnect would be the best initial troubleshoot method. get ready to lose all of your radio settings, although i think not having radio is worse haha.
mezdup is offline   Reply With Quote
Old 01-02-2013, 01:00 PM   #4
WiKKiD
WiKKiD Large Penis
WiKKiD's Avatar
Drives: 2001 Audi TT Quattro "BT 300+Whp"
The brz doesn't lose anything. Frs might though idk
WiKKiD is offline   Reply With Quote
Old 01-02-2013, 01:11 PM   #5
Re~Mix
Re~Mix's Avatar
Thanks for the tip, where exactly do I locate the battery cable to the radio? Or you saying to disconnect the entire car battery for a minute or two?
15' 228i MSport
Old 01-02-2013, 01:15 PM   #6
WiKKiD
WiKKiD Large Penis
WiKKiD's Avatar
Disconnect the main battery negative cable. But I would get it looked at before you do that by the dealer because if it happens once it's bound to happen again. The issue should have never happened in the first place. So get it fixed permanently not temporarily
Old 01-02-2013, 01:43 PM   #7
Re~Mix
Re~Mix's Avatar
Thanks, definitely the logical thing to do. I will swing by the dealer to look at the ESU as well (just received a letter from Toyota on the issue).
15' 228i MSport
Old 01-02-2013, 08:05 PM   #8
Re~Mix
Re~Mix's Avatar
Got in the car this afternoon and everything worked flawlessly.
Hoping it was either my post NYE stupor or a fluke that caused the hiccup. Will document the occasion and follow up with the dealer.
15' 228i MSport
USB on the stock radio Dadhawk Electronics | Audio | NAV | Infotainment 70 02-25-2013 05:48 PM
Replacing Stock Radio w/BeSpoke im2fr-s Electronics | Audio | NAV | Infotainment 2 12-04-2012 02:10 AM
Stock Radio Settings... ScionFrsFan Electronics | Audio | NAV | Infotainment 2 11-18-2012 09:08 PM
Is your stock radio sounding iffy? ThaBigUnit Electronics | Audio | NAV | Infotainment 1 10-22-2012 01:54 AM
