Drives: none
How to determine stock ECU map version (and datalogging)
So, long story short, I took my car into the dealer to have them look at what I believed to be the throttle-tip in detonation issue. They claimed they couldn't reproduce it and said there are no updates for my ECU... So... since I can't seem to get Subaru to look into this, is there any way for me to:
A) Determine which version of the stock programming is on my ECU and compare that to a known list of updates? B) Datalog the stock ECU over OBD to see if the ECU itself is detecting the detonation, or if I'm just hearing something else. Most of the datalogging threads on here seem to relate to datalogging with the OFT or Ecutek... I understand I could solve most of this by just buying an OFT and flashing an appropriate tune for my car. However, I would prefer to have some concrete data to bring to the dealer. I have a bluetooth OBDII reader as well as a USB VAG-COM/VCDS cable from back when I owned my Jetta (it can read general OBDII as well). Any suggestions? Thanks! -Matt |
Drives: 2015 86 GTS
Not sure which phone/tablet you have, but the "Torque" app (Android) will work with an ELM327 style OBDII bluetooth adapter.
This will most likely give you your ECU ROM Calibration ID. It will also record a number of common values, but I am a little unsure if it will give you knock values. I doubt it will give you coarse correction (i.e. IAM or Knock Correction values), but may give you fine correction (FLKC) to highlight any knock. Maybe give it a shot ![]() Steve's post below provides a guide to the different ROMs based on country/region and transmission type. http://www.ft86club.com/forums/showthread.php?t=62332 |
| The Following User Says Thank You to fibble For This Useful Post: | armstrom (06-22-2016) |
All the service bulletins contain VIN ranges. You should be able to use that to see if you're affected.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
Drives: none
I have an android phone and android headunit in the car as well as a pro license for Torque. I hadn't noticed Torque reporting the calibration ID but I'll dig deeper when I get home.
Is there any way to configure torque to log/display the knock sensor info? When I last went through all of the available data channels I couldn't find anything that worked for knock. As for a service bulletin, as far as I can tell neither Toyota/Scion nor Subaru in North America have issued a TSB for this detonation issue. The only TSB I've been able to find is issued by Toyota of South Africa. OFT claims all of their tunes incorporate the fix but I'm really trying to stay stock to preserve my warranty, at least for a while. -Matt |
Drives: Toyota 86 GTS
Tactrix or OFT will let you datalog and flash stock rom before going to the dealer.
The differences are: - OFT is 3x the cost - Tactrix can log more channels but will require more homework for MY15/MY16/etc - OFT can display some data in real-time while logging which can help you MUCH faster replicate the situation you're targeting. |
#6 | |
you can use toyota techstream to log any rom calid, the update rate can be a bit slow though but it will log knock parameters heap of links below to get you started Link to Techstream software and info http://www.ft86club.com/forums/showthread.php?t=35530 you can use a Tactrix cable or an VAG Com or a VCI cable to connect to ECU and use Techstream. |
| The Following User Says Thank You to steve99 For This Useful Post: | armstrom (06-22-2016) |
| Latest OTS Version for Stock Car | Kayysonie | Software Tuning | 7 | 09-18-2015 03:46 PM |
| FS/Feeler: stock brz nav headunit (US version) | robot | Audio/Visual, Electronics, Infotainment, NAV | 4 | 11-29-2013 12:23 AM |
| How to determine whether TSB applies to my car? | qqzj | Issues | Warranty | Recalls / TSB | 2 | 11-12-2013 06:08 PM |
| EcuTek Datalogging Question | xxscaxx | Engine, Exhaust, Transmission | 8 | 05-24-2013 12:31 AM |
| Does how you drive determine how good you are at sex? | ichitaka05 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 08-10-2011 01:35 AM |
