Old 06-21-2016, 07:55 AM   #1
pooch
pooch's Avatar
Drives: 2013 Scion FR-S (M/T)
Clearance and spacer query
Thinking about getting a set of Prodrive P1 ($300 for the set can't go wrong imo) but thy are 17x7 +52 vs our +48, so I have 2 questions:
1) should I be concerned about backspacing although I know 4mm doesn't sound like much past experiences 4mm can make a world of difference.
2) has anyone had issues with hubcentric spacers (not the ones with the bolts but rather the "inserts" since I have ARP extended lugs on my car)
Thanks in advance!
pooch is offline   Reply With Quote
Old 06-21-2016, 08:11 AM   #2
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I run 17x7 +52 BBS off an 02 WRX with 20mm bolt on spacers and it looks perfect. I plan to run ARP extended lugs, and press out the wheel bolts in the spacers to make it function as a slip in.
I tested that on my Forester XT which has ARP lugs and it worked great.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 06-21-2016, 08:13 AM   #3
pooch
pooch's Avatar
Thaaaaaaaaaaaaaank you, literally just made my day,lol.
Old 06-21-2016, 08:30 AM   #4
JazzleSAURUS
How that fitment looks with 225/45-17 on 1" Swift springs...
https://www.instagram.com/p/BG5e_TBNIMk/
AUSTRALIAN 86 GTS Query alchemy AUSTRALIA 2 10-19-2014 09:04 PM
AUSTRALIAN 86 GTS query alchemy Scion FR-S / Toyota 86 GT86 General Forum 11 10-17-2014 04:21 PM
Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-03-2014 12:53 PM
GT86 Wheels Query slord93 AUSTRALIA 4 01-26-2014 10:58 AM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 11:59 AM
