Old 06-13-2016, 10:10 AM   #1
Silver Cervy
*Some really cool title*
Silver Cervy's Avatar
Anyone have pics showing their wheel offset?
I've been looking at wheels for awhile, but for all the ones that I've checked out I can't get a good look at how pronounced the offset is. Most of the ones I've seen have either 40 or 45 mm but idk how that actually looks in person. Can anyone who has pictures showing their wheel offset post them here to give me a good idea how it looks? Please include the measurement as well.
Silver Cervy is offline   Reply With Quote
Old 06-13-2016, 01:00 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.ft86club.com/forums/showthread.php?t=7535
and...
You cannot tell how "pronounced the offset is" by a picture. +45 offset on a 7" wide wheel is not the same as +45 on a 10" wide wheel.
I think you need to clarify what you are looking for...
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Leonardo (06-13-2016)
Old 06-13-2016, 07:29 PM   #3
Silver Cervy
I'm looking at 8" wide wheels. I know that negative offset is the "deep dish" style of wheel, and I've seen many in person, but I've never seen wheels where the spokes are protruding farther out than the actual wheel is.
It's possible that I'm being an idiot and getting this wrong, but I've looked at multiple sources explaining wheel offset and it's still confusing me. Is it just an aesthetic thing or does it actually effect wheel fitment?
Old 06-13-2016, 07:46 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Please click and read the first two links...
https://www.google.com/search?site=&...i3.jDfpsICQBoQ
Old 06-13-2016, 09:52 PM   #5
Silver Cervy
Ok, I think I get it now. Negative offset = wider stance and positive offset = narrower stance, basically. Still kind of confused about how changing wheel size but not offset can be bad for a car.
Old 06-14-2016, 01:48 AM   #6
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
www.frsproject.com
Just play with this and you will soon understand what offsets are and which offsets and width wheels fit our cars best
DuMa is offline   Reply With Quote
Old 06-14-2016, 12:01 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Couldn't help it. I think they "originated" from H-Town. Swangas!
Old 06-14-2016, 12:40 PM   #8
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
That's actually a very good example of how irrelevant the spokes of a wheel are when it comes to the wheel's ET number. It's strictly the relationship of the wheel's mounting surface at the hub as compared to the centerline of the wheel's width. The spokes can be whatever shape the designers want.
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
Leonardo (06-14-2016)
Old 06-14-2016, 01:09 PM   #9
mav1178
mav1178's Avatar
I'll just be nice...
You need to do research. And you need to actually read what you look up.
Offset has nothing to do with wheel stance, wheel width, or even spoke design.
Offset is, simply, the measurement (in mm, usually) from the centerline of the wheel to the mounting surface of the wheel.
This info by itself is relatively useless unless you know what width the wheel is, then the two can be put together to determine fitment.
Before you confuse yourself, you need to look at each aspect of wheel spec and take it at face value, then combine them once you fully understand what it means.
http://www.autoanything.com/wheels-r...el-backspacing
-alex
Old 06-14-2016, 04:59 PM   #10
Bamsterman
Drives: 13' Scion FRS
Bamsterman is offline   Reply With Quote
Old 06-14-2016, 06:59 PM   #11
Silver Cervy
-alex
Taken from the link you provided...
"With a lower offset, your wheels mount farther outward, providing a wider vehicle stance."
When I said negative offset = wider stance, I meant generally and not in all cases. No need to call me out just because I know less than you do.
Old 06-14-2016, 07:53 PM   #12
mav1178
mav1178's Avatar
Generally, yes, but offset is like tire aspect ratio. It's useless without knowing the rest of the specs.
The link says what you quoted, but it also assumes you are using the same width wheels for reference.
Believe it or not, 8" wide +35 offset wheels have a more narrow stance than 9" wide wheel with a +45 offset, assuming it's from the same manufacturer. As I said in my previous post, wheel offset is useless if you don't know width.
-alex
Old 06-14-2016, 08:24 PM   #13
Silver Cervy
I assume it's just a matter of converting everything into inches. Once you know how much percentage of an inch is being added in offset you'd factor in the increased wheel diameter to figure out the true positioning of the wheels.
I could still be talking out my rear end though. Just trying to put it in a way that makes sense to me.
Old 06-14-2016, 08:55 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Man, it's phrases like " I assume" and " a way that make sense to me " that are frustrating. If you understand the material, you won't have to assume or make it make sense.
Wheel fitment is a multifaceted and complicated thing. Please keep reading.
Effect of wheel offset ddeflyer Tracking / Autocross / HPDE / Drifting 8 07-02-2014 06:29 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
Lowered 1" and have a 265/35 or 255/35 tire +38 offset please post pics! ScionFR-S Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-30-2014 02:26 PM
Stock Wheel offset smbrm Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-15-2012 12:09 PM
wheel offset post pics! gt86init Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-06-2012 05:23 PM
