Drives: 2016 Scion FRS Halo
Tire setup for drifting
I'm trying to figure out a good tire set up for drifting on stock power maybe up to 300hp. Does tire thickness (aspect ratio) matter? What about tire diameter? Based on the drifting thread it indicates that 215-245 mm for tire width but lacks info on wheel diameter and and tire aspect ratio. I also wanted to know how low is considered low to prevent the issue of snapping the cars axle.
[insert cool phrase here]
Drives: BRZ Premium
Stock setup works well enough.
Just go out to a nice skid pad or safe spot where you won't hit any curbs. Then turn off the nannies, and just have fun. Giggle like a school girl.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#3 | ||
Drives: 2014 WRB BRZ
I've been running 205s & 215 width tires, mainly just going with what I can find cheapest. 17 inch is by far cheaper than 18 or 19. |
LMGTFY
Drives: 13 FRS, 91 Miata
Personally the biggest I'd go would be 225 squared.
17x7.5/8 wheels. Better to learn on stock size and go from there. Everyone is different. |
#5 | |
Drives: 2005 Toyota Camry
Width varies but if you want to spin 245s be prepared to have more than 300HP and skill. Axles, surface condition matters more than ride height when it comes to drifting... -alex |
Drives: BRZ Premium
Also, don't forget skill.
Just like with everything, practice. With enough practice you can do your own Ken Block vid.
Sigh man... Feels bad when you have to go 17s and lose aesthetics... I wanted to do 18 inch wheels but I guess for function I have to sacrifice...
Sent from my Nexus 6 using Tapatalk |
#8 | |
Drives: BRZ Premium
Well you know what they say, "All show, No go". All those cars on car shows and parking lots don't do shit. It's just a huge circle jerk meet. When I was young I thought those guys where out on the track every weekend, till I went to a track. Didn't see any shiny car there at the end of the day. The ones that where there, couldn't take the heat and didn't stay after lunch.
Drives: Whiteout FRS
Yup don't really want anything bigger than a 215 on the rear with stock power. Also as far as axles snapping it really varies. I'm really low (I'm on air ride) but I haven't had a problem yet. But there has been a few guys with problems. Some people are more aggressive depending on the track with clutch kicking and what not. But if you're worried just don't go too low. You can look at the axle angle.
#10 |
Drives: Subaru BRZ
I think aspect ratio will come into play if the side walls deform as the tyre will fold thus giving the sense that you have lack of control. So isn't a stiffer sidewall better?
#11 | |
A stiffer sidewall is not better. Or worse. Tire pressure and compound (grip) is what matters. Drifting is about control (when spinning the tires), not about losing control. -alex |
#12 |
Drives: '13 10 Series FRS #1203
Alignment will matter more than anything else.
| Tags |
| drifting tire setup |
| Wheels setup advice to learn drifting | ShadowTS | Tracking / Autocross / HPDE / Drifting | 2 | 03-22-2016 03:26 PM |
| SM wheel and tire setup | aquaman | Tracking / Autocross / HPDE / Drifting | 8 | 10-28-2015 01:53 PM |
| Winter Tire setup | DVNARC | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 09-17-2015 01:17 PM |
| Advice on Tire setup | otterpop | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 03-11-2015 12:50 PM |
| Tire question for drifting | sandman126 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 01-29-2013 02:31 PM |
