Old 09-15-2015, 11:17 AM   #1
DVNARC
Drives: 2013 Black Scion FRS
Winter Tire setup
Hey so Living in Boston I def want winter tires for my frs and was thinking getting 225 in rear and keeping front 215.
Some questions:
1. I def want blizzaks but which blizzaks should I get?
2. Will I be okay lowering my car by an inch or would it be better to get meatier tires? Cuz my car is low enough I already scrape occasionally can't imagine going lower would be like��
3. Would it be a good idea to keep rear also thicker than front tires? Like the tire trim height? Whatever it's called not sure still learning
4. Also I notice looking at the car from the back the stock tires are in quit a bit I would like some meat to stick out a little if that makes any sense?
Thanks
DVNARC is offline   Reply With Quote
Old 09-15-2015, 11:26 AM   #2
CB390248
Drives: Asphalt FR-S
I would recommend skinnier or same size tires not wider for winter. I used blizzack lm 60 my first winter and Michelin xice3 (seem more like lm60) but I would recommend ws-70 which I have now for better "lots if snow" preparation as the lm 60 are more for cold light snow conditions while ws70/ws80 are more for deep packed snow/ice. I also went down from oem wheels to 16 inchers. Good luck. Also check out the numerous threads on this.
CB390248 is offline   Reply With Quote
Old 09-15-2015, 11:37 AM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yeah I second what CB390238 said. I ran Blizzak WS70's my first year, burn the rears out in 10k km's lol!! I put X-ice in the rear and blizzak on the front last year, worked very well for me. X-ice seem to last longer with my driving habits lol!
Old 09-15-2015, 11:53 AM   #4
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
WS80s are the way to go. Stock size will be fine, that's what I have. However, getting a set of 16" steelies with some 205/55/16s would work slightly better. But definitely stick with a square setup, and don't go more than the stock width.
Winter is very very fun in these cars.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 09-15-2015, 11:59 AM   #5
D_Thissen
D_Thissen's Avatar
I have 205/55/16 General Altimax Arctics on steelies and never had a problem plowing through snow.
Old 09-15-2015, 12:13 PM   #6
DVNARC
Can I see some pics? And what are "steelies" exactly?
Old 09-15-2015, 12:15 PM   #7
DVNARC
My logic is that the blizzaks will be so good that I can get wider back tires cuz to
Be honest I don't like how thin they are stock :/
Old 09-15-2015, 12:16 PM   #8
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Skinnier is better in winter if you expect a lot of snow. Non-staggered as previous mentioned. 16" steelies with a 195/55/16 or 205/55/16 are a good decision. That way you don't have to keep getting tires mounted and dismounted a bunch. Tires are also a bit cheaper.
Lows isn't too big a deal...
Though I will say. It's getting lifted an inch from stock height for this winter.
DustinS is offline   Reply With Quote
Old 09-15-2015, 12:19 PM   #9
DVNARC
Sexy!! So thats 16 rims with 55 hight and stock 205 with? And how much did you lower the car from stock? Can I get it lowered with the stock coilovers? Or do I need to get aftermarket don't know anything about lowering.
Old 09-15-2015, 12:22 PM   #10
DVNARC
And don't smaller rims allow you to accelerate faster if larger lowers acceleration?
Old 09-15-2015, 12:23 PM   #11
DustinS
DustinS's Avatar
Stock tires are a 215. but yes, this is a 205/55/16 on 16" WRX wheels. I am lowered a lot, not quite sure how much. You would need a set of springs or coilovers. I would suggest leaving it stock height until after winter if you don't have something ready to go on.
Edit: not really. Tire size will effect the acceleration but the 195/55-205/55 is pretty much the same as stock. Nothing will change
Old 09-15-2015, 12:24 PM   #12
Shark_Bait88
If you're basing the sizing of your snow tires on visual desires, you're doing it wrong. Not trying to be harsh, but tires are about function; especially in the snow.
Old 09-15-2015, 12:26 PM   #13
DVNARC
And would it be ok if they stick out more like this http://www.ft86club.com/forums/showthread.php?t=41083
Looking at my Stock Tires From The rear at An angle I see they are in the car
Old 09-15-2015, 12:27 PM   #14
DVNARC
Yea I know but I'm looking for both looks and function
WTB: Steelies for winter setup in North NJ/NYC or Philly bayank NY / NJ / CT / PA 0 11-12-2014 01:52 PM
Winter suspension setup R2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 11-02-2013 02:20 PM
Winter Wheel/Tires setup - cheap and awesome! seven Wheels and Tires 5 02-25-2013 02:12 PM
Winter setup cnk NY / NJ / CT / PA 72 12-13-2012 08:48 PM
RPF1 winter setup whiteout fr-s Scion FR-S / Toyota 86 GT86 General Forum 6 10-27-2012 12:29 PM
