Old 06-10-2016, 06:02 AM   #1
ghostzfh
Drives: 2016 Scion FRS Halo
Tire setup for drifting
I'm trying to figure out a good tire set up for drifting on stock power maybe up to 300hp. Does tire thickness (aspect ratio) matter? What about tire diameter? Based on the drifting thread it indicates that 215-245 mm for tire width but lacks info on wheel diameter and and tire aspect ratio. I also wanted to know how low is considered low to prevent the issue of snapping the cars axle.
ghostzfh is offline   Reply With Quote
Old 06-10-2016, 08:00 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Stock setup works well enough.
Just go out to a nice skid pad or safe spot where you won't hit any curbs. Then turn off the nannies, and just have fun. Giggle like a school girl.
Old 06-10-2016, 09:33 AM   #3
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
Like Mr.AC said, stock setup and size works well. I'm still on stock suspension, and you can't go much wider than 225's in the front (for added grip), and any bigger in the back and you won't be able easily get the back end out or continue a drift with stock power.
I've been running 205s & 215 width tires, mainly just going with what I can find cheapest. 17 inch is by far cheaper than 18 or 19.
CarzCarzCarz is offline   Reply With Quote
Old 06-10-2016, 06:47 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Personally the biggest I'd go would be 225 squared.
17x7.5/8 wheels.
Better to learn on stock size and go from there.
Everyone is different.
Old 06-10-2016, 09:02 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Aspect ratio and diameter doesn't matter as long as you have the same front/rear.
Width varies but if you want to spin 245s be prepared to have more than 300HP and skill.
Axles, surface condition matters more than ride height when it comes to drifting...
-alex
Old 06-10-2016, 09:23 PM   #6
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Also, don't forget skill.
Just like with everything, practice. With enough practice you can do your own Ken Block vid.
Old 06-10-2016, 09:52 PM   #7
ghostzfh
Sigh man... Feels bad when you have to go 17s and lose aesthetics... I wanted to do 18 inch wheels but I guess for function I have to sacrifice...
Sent from my Nexus 6 using Tapatalk
Old 06-10-2016, 11:47 PM   #8
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Yeah..... Don't tell me your that kind of person.
Well you know what they say, "All show, No go". All those cars on car shows and parking lots don't do shit. It's just a huge circle jerk meet.
When I was young I thought those guys where out on the track every weekend, till I went to a track. Didn't see any shiny car there at the end of the day. The ones that where there, couldn't take the heat and didn't stay after lunch.
Old 06-11-2016, 01:11 AM   #9
JDM Haze
JDM Haze's Avatar
Drives: Whiteout FRS
Yup don't really want anything bigger than a 215 on the rear with stock power. Also as far as axles snapping it really varies. I'm really low (I'm on air ride) but I haven't had a problem yet. But there has been a few guys with problems. Some people are more aggressive depending on the track with clutch kicking and what not. But if you're worried just don't go too low. You can look at the axle angle.
JDM Haze is offline   Reply With Quote
Old 06-11-2016, 03:45 AM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
-alex
I think aspect ratio will come into play if the side walls deform as the tyre will fold thus giving the sense that you have lack of control. So isn't a stiffer sidewall better?
Old 06-11-2016, 05:24 PM   #11
mav1178
mav1178's Avatar
Your reasoning is not based on actual drifting experience.
A stiffer sidewall is not better. Or worse.
Tire pressure and compound (grip) is what matters. Drifting is about control (when spinning the tires), not about losing control.
-alex
Old 06-12-2016, 07:21 PM   #12
Shady195
Drives: '13 10 Series FRS #1203
Alignment will matter more than anything else.
Shady195 is offline   Reply With Quote
drifting tire setup
Wheels setup advice to learn drifting ShadowTS Tracking / Autocross / HPDE / Drifting 2 03-22-2016 03:26 PM
SM wheel and tire setup aquaman Tracking / Autocross / HPDE / Drifting 8 10-28-2015 01:53 PM
Winter Tire setup DVNARC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-17-2015 01:17 PM
Advice on Tire setup otterpop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-11-2015 12:50 PM
Tire question for drifting sandman126 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 01-29-2013 02:31 PM
