Old 06-09-2016, 11:05 PM   #1
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Best offset range to use with 17x7.5 wheels?
The title pretty much says it all.
My stock 17x7.5 wheels, pretty sure they are a +42 or +43 offset. Given this wheel size, what is a good range of offset to go with? (I see as low as a +34, as high as a +50 , what are the pros-cons with going to a certain level of offset ?).
Adam_L is offline   Reply With Quote
Old 06-10-2016, 05:17 PM   #2
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Stock wheels are 17x7 and ET48.
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
Leonardo (06-10-2016)
Old 06-10-2016, 05:29 PM   #3
gramicci101
Off Topic
Posts 2 and 3 will answer all your questions.
http://www.ft86club.com/forums/showthread.php?t=7535
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 06-10-2016, 05:44 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I can't find the offset, but I'm pretty sure the RS2 has 17x7.5 forged wheels.
OP, your wheels are fine the offset they are. If you want different wheels, read through the wheel directory. So much good info.
Old 06-10-2016, 05:56 PM   #5
venturaII
venturaII's Avatar
Ah - didn't catch the RS2 part...
17x7 +30 offset?!?!?!?!?!?!?! Leight1104 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 01-06-2016 01:07 AM
FS- Kosei K1TS 17x7 wheels 50mm offset- Autocross LIGHT! solort Wheels and Tires 2 07-09-2015 04:08 PM
17x7.5 +40 offset project d CANADA 2 01-17-2014 12:02 PM
Autec Zenit 17x7 40 offset KBRZee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 07-08-2013 04:39 PM
Let's talk Offset. 17x7.5 +35 Tainen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 06-28-2012 04:57 PM
