CANADA Canada
Old 01-16-2014, 08:07 PM   #1
project d
Drives: 2013 BRZ WRB
17x7.5 +40 offset
Hey everyone,
not too sure about this setup... is this compatible with an OEM or slightly lowered setup?
I do not want to disturb the OEM suspension geometry by replacing the offset.
thnx
project d is offline   Reply With Quote
Old 01-16-2014, 10:42 PM   #2
Steve
Steve's Avatar
Drives: 6MT
Yes it is fine, the stock wheel is 17x7 +48, so that is not far off from stock specs
that's an 8mm difference in offset, and 1/2 an inch wider wheel
geometry will not be affected
the wheel will poke out maybe 2cm more than the stock wheel, noticeable, but subtle still
Steve is offline   Reply With Quote
Old 01-17-2014, 12:02 PM   #3
project d
Thnx
Wheel Directory: Motegi MR125 17x7.5 +42 mechaghost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 08-16-2013 12:41 PM
Autec Zenit 17x7 40 offset KBRZee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 07-08-2013 04:39 PM
Enkei RPF1 17x7 42mm offset brz7400 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-08-2013 06:26 PM
Let's talk Offset. 17x7.5 +35 Tainen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 06-28-2012 04:57 PM
Volk Racing GT-C 17x7 and Gram Lights 57 Optomise 17x7 xravexboix Wheels and Tires 0 05-24-2012 08:04 PM
