Old 06-06-2016, 07:54 PM   #1
euthqt
Drives: 2013 Scion FRS 10 Series AT
Transmission Fluid Temperature
So I'm trying to get my transmission to the right temperature to check my fluid properly for the AT transmission (which requires the temp to be between like 42-47c) and the car is never cool enough when I check. I took it today and left the car off for three hours to cool down and when I put the car into the oil temperature check mode, it still showed an up arrow saying it was too hot. I'm leaving the car overnight to try again tomorrow.
Has anyone else had a similar issue?
euthqt is offline   Reply With Quote
Old 06-06-2016, 11:23 PM   #2
SimplyIcy
Drives: 2015 K1X_Halo FR-S
I've never had an issue with that when I installed a Transmission Cooler from SSP Performance. Stock I could never get it to go. Extremely annoying, if you have a cooled/heated garage try that. otherwise I'm not sure!
SimplyIcy is offline   Reply With Quote
Transmission Fluid euthqt Issues | Warranty | Recalls / TSB 8 04-14-2016 08:20 AM
Manual Transmission Fluid, GL-3 vs. GL-4 ducky106 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 11-10-2015 06:40 PM
MT Transmission Fluid mstoochn Scion FR-S / Toyota 86 GT86 General Forum 1 06-14-2015 09:06 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
FS: AEM 30-4402 Oil/Transmission/Water Temperature Digital Display Gauge. Sportsguy83 Engine, Exhaust, Bolt-Ons 4 03-25-2013 10:37 AM
